Old 03-26-2024, 09:28 AM   #1
coolcoupe
coolcoupe's Avatar
Default rear drum studs
I have a 1940 rear drum that I want to put on my 1947 car (its in storage) But
the studs don't seem very long. Will the rim/tire still mount on it ?
coolcoupe is offline   Reply With Quote
Old 03-26-2024, 09:35 AM   #2
KiWinUS
KiWinUS's Avatar
Default Re: rear drum studs
More information and pictures needed to give correct answers
KiWinUS is online now   Reply With Quote
Old 03-26-2024, 12:14 PM   #3
Kube
Kube's Avatar
If it is a true 01A rim (1940) it'll work just fine as it is on your '47.
Old 03-26-2024, 01:32 PM   #4
coolcoupe
coolcoupe's Avatar
Actually this is a replacement drum that I picked up to replace my old one. The studs look shorter than my 47. My car is in storage so can't look at them right now. Were all the studs for 40-48 the same ?
Old 03-26-2024, 01:43 PM   #5
Kube
Kube's Avatar
Passenger car studs were the same between '40 - '48.
Old 03-26-2024, 02:07 PM   #6
coolcoupe
coolcoupe's Avatar
That is sooo good to hear !!! It must of been my eyesight or old age creeping in .
Old 03-27-2024, 06:52 AM   #7
alchemy
alchemy's Avatar
You mean a drum/hub assembly, not a reproduction drum, right? And, the studs you found were the same length as original, not something a parts book jockey handed to you, right?
alchemy is offline   Reply With Quote
Old 03-27-2024, 03:38 PM   #8
coolcoupe
coolcoupe's Avatar
Yes, its a good used drum/hub assembly I bought a little while ago. It is a 1940 drum/hub that I want to put on my 47 car.So I was hoping it would fit without any problems.
I am replacing the bearing and seals but wanted to know after removing the snap ring, how to remove the grease seal ? any tricks without hammers ?
Moe
Old 03-27-2024, 03:52 PM   #9
Tim Ayers
Moe
Seal puller. Can get one at any auto parts store or online of course.
The seal is not usable once you pull it, so have a new one ready to install in it's place.
Old 03-27-2024, 04:19 PM   #10
coolcoupe
coolcoupe's Avatar
Thanks Guys
Old 03-27-2024, 05:23 PM   #11
Newc
Newc's Avatar
There are Wheel differences as to lug holes ! Innies vs outies, pre war vs post war. If lug nut only uses half of its threads, you will see the difference in length. Newc
Old 03-27-2024, 08:03 PM   #12
coolcoupe
coolcoupe's Avatar
Newc, but they will fit right ?
Old 03-27-2024, 10:07 PM   #13
Newc
Newc's Avatar
Fit by bolt circle is the same, But the studs can be tooo short for some wheels. My forty with post war 15" had only half the threads used in the lug nuts. Newc
Old 03-28-2024, 02:12 PM   #14
coolcoupe
coolcoupe's Avatar
Using only half the thread does not seem safe. So my 47 rim will mount alright on a 40 drum/hub ok ?
Old 03-28-2024, 02:50 PM   #15
Kube
Kube's Avatar
Your 47 rim will mount perfectly on the 40 drum.
Old 03-28-2024, 04:15 PM   #16
coolcoupe
coolcoupe's Avatar
Final answer. I will let rest
Old 03-28-2024, 08:11 PM   #17
Lanny
Lanny's Avatar
Yes, your '47 wheel will fit the '40 drum, but as has been said, the
lug studs on the '40 drum will be to short for a safe fit of the '47
wheel.
The '40 and the '47 wheels have different styled lug nut holes !!!
Click on pics to Enlarge
!st pic is '40-'41 Ford Wheel... 2nd. pic is '46-'48 Ford wheel.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 03-29-2024, 11:04 AM   #18
Lanny
Lanny's Avatar
bttt with pictures added of Ford wheel lug holes.
Old 03-29-2024, 11:43 AM   #19
petehoovie
petehoovie's Avatar
wheel.
1st pic is '40-'41 Ford Wheel... 2nd. pic is '46-'48 Ford wheel.
Old 03-29-2024, 12:56 PM   #20
coolcoupe
coolcoupe's Avatar
I had ask this question 6 months ago but did not get a reply about the wheels not fitting I guess I did not ask the right way. What are my best options now ?
