Old 01-16-2016, 01:23 PM   #121
George Miller
George Miller's Avatar
Default Re: 5 main, chev, crankModel A engine
Originally Posted by forever4 View Post
Make sure you don't get any Ford engine green paint on the white asbestos filler on the head gasket, or you will lose points in judging!
Good point maybe I could use fine line tape.
George Miller is offline   Reply With Quote
Old 01-28-2016, 02:04 PM   #122
George Miller
Did a little work on the engine. To cold and wet to paint it, so I worked on clutch. Drilled the chev flywheel for a Mustang pressure plate. Using a 9" clutch plate that fits the 39 Ford transmission. Made bushing for the end of the crank so I could use the ford A Pilot bearing. Reworked the chev V8 starter to fit the Ford block with the chev flywheel.
Firing order for those that were wondering. hits on 1 then 3 skip hits on 2 skip skip hits on 4
Old 01-29-2016, 03:48 PM   #123
hardtimes
hardtimes's Avatar
Hey George,
Awesome , thanks for update . Well, firing order IS close to fords banger, eh !
Who needs a 'stinken auto supplier' store, when you are around !
Geeze, I hope that you have this ALL documented ...in case something has to be 'ordered' by next guy with this
hardtimes is offline   Reply With Quote
Old 02-01-2016, 06:04 PM   #124
George Miller
We are getting there.
Old 02-01-2016, 09:39 PM   #125
hardtimes
hardtimes's Avatar
Wonderful pictures, thanks for sharing ! How close to firing off ?
Will you have it on a stand for first test firing or in vehicle ?
Boy, did I ever learn the value of not putting my new B in the car for first start up. Have done it both ways, but getting to where it isn't as easy to remove it as it used to be
Old 02-01-2016, 10:11 PM   #126
George Miller
I'm going to put it in the hill climb car. I need to make sure every thing fits right. Then after it is runs some, will take it out and finish the hill climb car. Will be starting it before to long. Still have some things to take care of. Seems like the list of things to do gets bigger.
Old 03-03-2016, 10:09 AM   #127
George Miller
Update on engine. Been working on the hill climb car (or should I say truck) with some friends.
Tried to get oil pressure on the engine. Pump did not want to work on the out side of engine. So reworked the camshaft and put a drive gear in the center from a Model A cam. Now we can use a oil pump drive from the A engine with the oil pump on the inside. Now we can move on to the next challenge.
Old 04-26-2016, 01:49 PM   #128
George Miller
update.
Had the engine running for a short time. Did not run well, so set it a side and put the other engine that I have in my hill climb car. We are running out of time to get the car done. I think the problem is the cam shaft timing. It will have to wait until next winter.
Old 04-26-2016, 04:19 PM   #129
Rowdy
Sorry to hear it did not run well. One thing I have been pondering; is this the same crank that Tod has in mind for his 5 bearing block? Probably should as in Tods block thread, but was wondering exactly what to do for a crank when I can afford a block in a few years. Might be time to find a couple of cheap cranks to offset the cost of such a build. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 04-26-2016, 04:34 PM   #130
George Miller
No this is a chev V8 crank. It is a 90 degree crank. I'm sure Tods will be 180 degree. With a 180 you can use the Model A cam. I think you would have to get a crank from Scat or one of the others that make special cranks. Maybe Tod will give us the answer.
Old 05-13-2016, 12:54 PM   #131
rowens55
rowens55's Avatar
George, any news on this engine? I was sorry to read the initial start up did not go well. Hoping to see a video soon of that bad boy runnin!
Rowen
Alive n kickin n mostly kickin!
rowens55 is offline   Reply With Quote
Old 05-13-2016, 03:51 PM   #132
George Miller
Rowen
It will be awhile before I can get back working on it. hill climb next week. Then get caught up on other jobs that got behind on.
Old 06-28-2016, 05:56 PM   #133
Missouri A
Missouri A's Avatar
Get er done!!!!!
Missouri A is offline   Reply With Quote
Old 06-28-2016, 06:19 PM   #134
George Miller
Originally Posted by Missouri A View Post
Get er done!!!!!
Here is where we are. It will be 3 weeks before I can try to start her.
Will post at that time how it worked out.
Old 06-28-2016, 06:29 PM   #135
aonemarine
aonemarine's Avatar
George.....out of curiosity did you happen to look at a mecruiser 470 crank to see if it was possible to fit into an A block or know anyone that has?
aonemarine is offline   Reply With Quote
Old 06-28-2016, 07:27 PM   #136
George Miller
If it is a GM 151 engine yes I did. It will not fit. In fact I have one.
Old 06-28-2016, 07:37 PM   #137
aonemarine
aonemarine's Avatar
no totally different beast....much bigger!!
Old 06-28-2016, 07:40 PM   #138
George Miller
Then no I have not tried that one.
Old 07-21-2016, 08:27 PM   #139
George Miller
Well we got it running tonight. It sounds good, but have some little things to take care of.
The guys took a video of it running and are going to put it on the Ford Barn.
Old 07-22-2016, 12:08 AM   #140
tbirdtbird
YaY we need a link to the video.....!!!!!
'31 180A
tbirdtbird is offline   Reply With Quote
