05-06-2020, 08:38 PM | #1281 |
Re: Test Photos by Mercman
1955 and 1956 Ford Sunliner Quarter Window Frames.
05-06-2020, 10:30 PM | #1282 |
1956 Ford Victoria Quarter Window Frames.
05-06-2020, 10:40 PM | #1283 |
Picture on the AACA Website of a Convertible Quarter Window Frame.
05-06-2020, 11:52 PM | #1284 |
Rare 1962 Falcon Two Door Station Wagon for sale in Australia.
05-07-2020, 11:25 PM | #1285 |
Neat 1956 Ford Parklane Station Wagon
05-08-2020, 04:57 PM | #1286 |
05-10-2020, 12:32 AM | #1287 |
Another Ford with this accessory trim behind the original badge
05-11-2020, 06:18 AM | #1288 |
Bracket and spring on an Australian 1939 Ford hood mounted the correct way with the spring at the bottom.
05-11-2020, 06:25 AM | #1289 |
Here is an old photo of a 1952 Ford Customline with a different accessory trim piece behind the original Ford badge.
05-13-2020, 01:03 AM | #1290 |
Australian 1939 Ford Deluxe Hood bracket and spring. The spring is in the correct position at the bottom, but the brackets should be swapped around right to left and left to right so that the spring is on the inside, not the outside like on this example.
05-13-2020, 01:30 AM | #1291 |
Yet another After-Market Accessory V8 Badge behind the original Ford Crest Badge. This one on a 1953 Ford Victoria.
05-13-2020, 01:40 AM | #1292 |
1960 Ford Ranch Wagon
05-13-2020, 02:39 AM | #1293 |
Nice Flathead with ARDUN heads on Test Stand - how sweet is this?
05-17-2020, 04:01 AM | #1294 |
Similar accessory V8 Trim for trunk lid of a 1952 Ford. On 1953 and 1954 Fords, the normal trim has to be removed to fit this accessory item?
05-18-2020, 02:45 AM | #1295 |
Fifteen Millionth Model T Ford
05-19-2020, 06:13 AM | #1296 |
1909 Ford Model T Touring on display at the Model T Ford Piquette Plant.
05-20-2020, 04:21 AM | #1297 |
The Edsel Affair by C Gayle Warnock
05-20-2020, 04:37 AM | #1298 |
Author of the Edsel Affair - Gayle Wardock
05-20-2020, 11:07 PM | #1299 |
Western National Meet - 2020
05-21-2020, 06:18 AM | #1300 |
Australian 1939 Ford Deluxe with the Hood retention spring in the correct position.
