08-15-2018, 01:21 PM | #101 |
Re: 1955 ford station wagon with a V8 302 Engine.
When doing a 289-302 swap in a 1952-56 Ford you can use the 1965-69 "short" water pump and matching shorter balancer the lower hose will then be on the passenger side,1n 1970 the SBF's used a longer water pump and the lower hose was moved to the driver's side. The early "short" pump gains about 3" more water pump to radiator clearance when replacing a y-block or flathead V8 the Six cylinder cars have the radiator mounted more forward and a different lower splash pan.
08-15-2018, 01:28 PM | #102 |
This is a 1967 Mustang 289 this may be the water outlet and hose you will need (very common with the SBF swap)
08-15-2018, 01:44 PM | #103 | |
Never stand to one side... Why am I reminded of THE THREE STOOGES trying to figure out right and left hand nails... Or being sent to the service truck to get a LH monkey wrench? Or the drill sergeant yelling out "YOUR OTHER LEFT!"?
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
08-21-2018, 11:48 AM | #104 |
I got my new radiator in yesterday.I started to install it this morning but I noticed that as I sit it on its bottom support bracket,the bottom hose outlet of the radiator is right in front of the sway bar and therefore,I cannot install my bottom hose cause of the sway bar being in the way.My question is this,does the rad.have to sit on its bottom support or can I raise it about an inch and than just make different mounting holes to hold it up on that position? The new Rad.is 1" shorter height wise and therefore raising it up is no problem.By doing this,the rad.outlet will be above the sway bar and thus letting me install the bottom hose.Do you think this will work ok or do you have other suggestions? Please let me know asap so that I can hopefully put this rad.in today.I really appreciate all of your help with this problem.
Mando |
08-21-2018, 02:05 PM | #105 |
I'm not sure how the stock radiator fits to the lower support
but sight unseen your solution sounds reasonable. Once you drill even one new mounting hole you can't return it, but you knew that. That extra inch at the bottom should be covered with something to block the air from sneaking past the radiator without going thru it. . Last edited by dmsfrr; 09-18-2018 at 11:29 AM. |
08-21-2018, 08:28 PM | #106 |
Mando |
