05-02-2017, 11:11 PM | #101 |
Re: Taking a break for some brakes.
New brake shoes arrived today, popped a new one on in place of the one that was extra thick and she spins free and the brake seems to operate smoothly. For the life of me I can't see much difference but all seems well.
05-07-2017, 10:57 AM | #102 |
My bolts arrived yesterday and they look great. $40 for an entire set of backing plate bolts, nuts, and cotters, front and rear. Now if I can get my wife to let me ignore the "honey-do" list for a few days...
05-08-2017, 09:22 AM | #103 |
Last Saturday I drove to Randy's shop (pre-arranged time and day) about 3.5 hrs away from my house with seven drums with hubs and new brake shoes from Snyder. (I would have had Randy do my linings but just recently heard of him, being a Newbie myself). Randy picked out 4 good hubs, switched hubs to his new cast drums, looked at all my bearings and races, had suggestions to replace most and had the whole job done in 4 hours. My wife and I went to the Autry Museum while we waited (just 30 minutes away). When we got back he showed me all he had done (along with arching my shoes to my new drums) helped me load them in my car and we were off for another 3.5 trip home to central CA. I am totally impressed with his knowledge, experience and ability to explain each detail of my "inexperienced questions".
I saved all that shipping and had a great experience. |
05-08-2017, 09:28 AM | #104 |
I saved all that shipping and had a great experience. I would recommend him to any one. |
05-08-2017, 10:21 PM | #105 |
Wow Phil, had so much fun you went twice! He is a pretty nice guy.
I'm starting to smell blood! Seeing the light at the end of the tunnel! One rear assembly is complete and torqued down... yahoo! It wouldn't take long to do the fronts but I want to get the more difficult rears finished and out of the way. Time to go read through the adjustment procedure... again. I'll probably have to go do it wrong a couple of times before it sinks in. |
05-13-2017, 05:18 PM | #106 |
https://www.youtube.com/watch?v=tzrx71Kb68s |
05-13-2017, 05:47 PM | #107 |
Congrats! One day late. You missed a great cruise to Mt. Vernon.
All steel from pedal to wheel |
05-13-2017, 06:31 PM | #108 |
Proably another day of adjusting too!
05-13-2017, 06:45 PM | #109 |
Congrats! Get them adjusted be for you have to do some body work :-(
05-13-2017, 07:05 PM | #110 |
Right on Art! I got mine going this weekend too. I had a bit of a temperature issue on my passenger front (according to my IR thermometer) but got it under control once I went through and checked the bearings and reset the brake adjuster. I ended up putting 31 miles on it this weekend. Good stuff.
Our 1931 Station Wagon: Originally restored in 1962, redone in the early 1980's, brought back to life in 1997 and refreshed in 2016/2017. Check out the progress at a31woody.com |
05-13-2017, 07:55 PM | #111 |
After I do a brake job and adjust them, I like to find a gravel road or sandy area and give it moderate braking to check the skid marks to see if they are even. Then I find an empty parking lot or side road, and give it moderate braking to see if it pulls to either side. If need be I will loosen one side a click or two to make it pull even side to side. Then drive it a few miles and use my temp gun to shoot all the drums to make sure none are hot.
05-13-2017, 09:41 PM | #112 |
The shoes obviously have a few high spots, I'm hoping to smooth those out before adjusting. My guess it will need adjusting again after a few miles.
05-14-2017, 05:49 PM | #113 |
Hey Art,
Did you notice just how many bolts and nuts that fit metric tools better than SAE? |
05-14-2017, 07:34 PM | #114 |
I have decided that you can't have too many 7/16, 1/2, and 9/16 wrenches, they're all a little different.
05-14-2017, 07:43 PM | #115 |
I snugged up brakes and rods and went for a real drive. working much better. I'd like to get 50, 100 miles on it then go through the adjustments outlined in the service bulletins. I think I may need to pull the front drivers back apart and add a shim/pill.
05-14-2017, 08:01 PM | #116 | |
Replacing the two push rods was all I had to do to fix that problem. |
05-14-2017, 08:13 PM | #117 |
Drivers side doesnt cant forward as much as I'd like.
Hey Tom, do you sneak a little jt-6 on the clevis pins? |
05-14-2017, 08:15 PM | #118 |
Also, what kind of temp were you finding on the drums after a drive?
05-14-2017, 08:17 PM | #119 | |
For me it was about 150 after a 5 mile test drive with moderate braking. Outside temp in the 60's. Sent from my iPhone using Tapatalk
05-14-2017, 08:35 PM | #120 | |
I like to use Mystic JT-6 High Temp red grease on any pins or moving parts, including both ends of the push rods for the front brakes. I also use it where the brake shoes rub against the backing plate. Just go light here so you don't get it on the shoes. |
