09-06-2018, 01:48 PM | #101 | |
Re: How To Lower The Model A The Old Fashion Way
Different strokes for different folks.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? Last edited by Chris Haynes; 09-07-2018 at 12:02 AM. |
09-06-2018, 02:17 PM | #102 |
Just let air out of the tires. Easy Peasy.
09-07-2018, 12:04 AM | #103 |
I'd like to see you drive your car with four flat tires.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
09-07-2018, 07:49 AM | #104 |
Well...It could be done.
09-07-2018, 12:57 PM | #105 |
I just called Posies. They don't offer reversed eye springs. They make a totally new spring which will sit your car at the height you want it.
09-07-2018, 01:31 PM | #106 |
09-07-2018, 04:17 PM | #107 |
Those are only 1/16" thick. Nominal Thickness 0.062"
Bob |
09-08-2018, 02:05 AM | #108 |
Bib,
How do you figure that a washer that measures 1/4" x 1.5" are only 1/16th thick?
09-08-2018, 08:37 AM | #109 |
There's someone on the thread below looking for suggestions on what to use for an inexpensive modern 16 inch tire.
If you have suggestions, respond to him. Thanks https://www.fordbarn.com/forum/showthread.php?t=250863 |
09-08-2018, 10:31 AM | #110 |
Read the specs.
Product Attributes Inner Diameter 0.281" Outer Diameter 1.500" Grade 18-8 Finish Plain Bolt Size 1/4" Material Stainless Steel Type Fender Washer System of Measurement Imperial (Inch) Nominal Thickness 0.062" Product Weight 0.0285 |
09-09-2018, 02:31 AM | #111 | |
Read more: http://www.businessdictionary.com/definition/nominal-dimension.html"
09-09-2018, 07:37 AM | #112 | |
09-09-2018, 08:12 AM | #113 |
If you read the entire list of specs you'll see the 1/4" refers to the "nominal" hole/bolt size (not thickness) as 1/4"
Luck occurs when preparation and opportunity converge. |
09-09-2018, 01:59 PM | #114 | |
As you can see the washer is 1/4" thick. 1.5" across. Has a 1/4" hole in the center. To be used as a spacer the 1/4" hole must be enlarged to 11/16"
09-09-2018, 02:49 PM | #115 |
OK, I don't know what to say. The first link is to the part number you gave and
the second link is to the specs for the stainless washers. Glad they are what you wanted. https://www.fastenal.com/products/details/0172787?fsi=1 https://www.fastenal.com/content/pro...FEND.SS.00.pdf These are the ones I got. https://www.grainger.com/product/5TA...rders_WillCall Bob |
09-10-2018, 01:41 AM | #116 | |
- Is this something new? I would guess that in the past they have sold far more reversed eye springs than conventional ones(?). |
09-10-2018, 02:59 AM | #117 |
McMaster Carr has the correct size washers. Center hole, outside diameter and thickness.
09-10-2018, 12:11 PM | #118 | |
I opted for Stainless. I just had my axle and wishbone powder coated and I don't want to wind up with rusty washers.
09-10-2018, 12:11 PM | #119 |
They sell washers that already have the 11/16" center hole?
04-01-2019, 09:59 PM | #120 |
I am still in the process of gathering parts for this. I have the '32-'36 front axle, '46 spindles and brakes. Now is the time for gathering hardware. Specifically the King Pins and Kit. Which should I use?
