Old 05-31-2015, 01:58 PM   #81
mrfliboy
mrfliboy's Avatar
Default Re: 1941 Ford Pickup frame-off restore for the next generation
Passenger side running board done.
Also got my radiator back, he says lost count after 5 or 6 leaks but all is good.
Also last pic shows my instructions for the Radiator shop, guess I can't complain too much, 2 other shops would not touch it.
mrfliboy is offline   Reply With Quote
Old 06-01-2015, 07:47 PM   #82
Sixseven
Sixseven's Avatar
Have you got to your left front fender yet? If not, take lots of pick as the damage you have is similar to what I have. I'd like to see how you make the repairs. Do you have a brake and a bead roller?
Sixseven is offline   Reply With Quote
Old 06-01-2015, 09:16 PM   #83
FlatheadTed
FlatheadTed's Avatar
Mr Fly boy great job, you obviously can turn your hand to any thing .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-01-2015, 09:56 PM   #84
mrfliboy
mrfliboy's Avatar
Not yet, still practicing on the metalworking. Right side fender is next mostly low around the edges to replace. Its much better shape than the left side.
No brake but a bead roller. I have access to a 8' brake a hours ride away.
Old 06-01-2015, 09:57 PM   #85
mrfliboy
mrfliboy's Avatar
Thanks for the kind words, learning as I go. And having fun the whole time.
Old 07-06-2015, 01:51 PM   #86
mrfliboy
mrfliboy's Avatar
Default You ever had one of those months??
I'm sure you all have been on pins and needles awaiting any updates on the old truck. Well there's been a reason for this.
Since the end of May I have been fighting with alignment issues with all the front sheet-metal. Hours of online searching with no avail. BTW some great articles out here.
After actually trying to com-along the cab back to shift it all and countless hours of tweaking, unbolting, elongating holes etc. I decided to strip all the front metal off and re-bolt the cab back down, square the doors etc.
I went and got the hardware for a proper bolt down of the cab and made up some spacers to seat it all properly. After this was complete and my doors were operating better than new (probably). I decided to start with the hood gapping first. As I had done before.
It wasn't until I went to install the bottom radiator shield and grill that I realized my mistake from months ago. I never installed the springs between the frame rails and lower radiator shield, lowering the whole grill assembly down 3/4". As soon as I dropped it down all the pieces fell perfectly into place.
No elongated holes needed, a drift pin some bolts and it all went happily into place. 6 weeks of aggravation, sweat and some cussing gone.
Now I am finally able to continue patching the passenger fender and than onto the other side.
Very very happy with the alignment of everything now. Thanks for letting me rant.
Old 08-02-2015, 01:23 PM   #87
mrfliboy
mrfliboy's Avatar
Back to fender patching 101,
Started on the back running board area, less visible and could use some more practice.
Next was a couple spots along the inner fender connecting area
Onto the small spot by the grill
Old 08-02-2015, 01:27 PM   #88
mrfliboy
mrfliboy's Avatar
And lastly the dreaded piece (atleast I've been putting it off) the whole bottom lip below and to the side of the headlight. Made up a heavy wire rod for the outline and than started shaping and trimming.Lots of hammering and shaping later we have a finished fender.
Also drove over to Detroit area and picked up some nice whitewalls. 27th anniversary and went to the Ford Museum and picked up some tires along the way (fellow ford barner, thanks). Gotta love a wife like that.
Drivers side next.
Old 08-02-2015, 07:41 PM   #89
Tinker
Tinker's Avatar
Nice progress. Getting closer!
Old 08-02-2015, 10:14 PM   #90
TomT/Williamsburg
TomT/Williamsburg's Avatar
Nice job on the fender and the entire truck - what is not to love about 40-41 pickups?!
TomT/Williamsburg is offline   Reply With Quote
Old 08-03-2015, 05:32 PM   #91
Vanspeed
Vanspeed's Avatar
Glad I could help with the tires, nice progress on that fender!
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 08-05-2015, 11:08 AM   #92
mrfliboy
mrfliboy's Avatar
Thanks all. Dog days of summer and all has slowed it down a bit, but still plugging away.
Old 08-28-2015, 06:27 PM   #93
mrfliboy
mrfliboy's Avatar
Default Here we go again Side2
Finally happy with the pass fender. Got lucky and dumpster dove my neighborhood and found a pile of pvc and fittings. Was able to build a complete fender stand for free. Worked out well for the headlight area holes to be filled.
Will do fine when I get to start painting this winter (maybe)
Started on the Drivers running board. Back bracket was toast. So fabbed up one from a piece of metal that was actually used to patch the floor of the cab.
Gauge was good and its got the patina. LOL
Old 08-31-2015, 04:44 AM   #94
Sixseven
Sixseven's Avatar
Thanks for the PVC stand idea, it's a great one. I'm looking at your shop which seems to be a small as mine. If you can do it, I guess I can too.
Old 08-31-2015, 09:43 PM   #95
mrfliboy
mrfliboy's Avatar
I'm sure you'll have no problem, just plug away.
I spend a lot of time rearranging for.... sure. A little planning goes along way.
Old 08-31-2015, 10:27 PM   #96
Mike in AZ
Mike in AZ's Avatar
very impressive work.....thanks for posting all the work as you've gone along.....very cool....Mike
Mike in AZ is offline   Reply With Quote
Old 09-04-2015, 11:55 AM   #97
mrfliboy
mrfliboy's Avatar
Default Big Smile!!!!!
Look what I picked up from a fellow barner.
Looks like its been there from Day 1.
Thanks again
Old 09-05-2015, 04:59 PM   #98
Sixseven
Sixseven's Avatar
I like your idea of using the bar stock for the fender form. Did you leave it in place or roll the new steel into the form, then remove the bar stock?
Old 09-05-2015, 07:25 PM   #99
mrfliboy
mrfliboy's Avatar
Yea Thanks it worked at well.
Rolled it and than removed. Definitely the way to keep the shape.
Old 11-16-2015, 10:00 AM   #100
mrfliboy
mrfliboy's Avatar
Quick little repairs on the headlight buckets.
On to the drivers running board. Lots of fun patching the hump areas, can't wait to apply body filler on those. LOL
Got the VW stored away for the winter and was able to get my framework mounted to the ceiling for my spray booth.
