01-06-2012, 09:36 PM | #61 |
Re: fuel line
Hope , I would imagine I'm in the running for the "some a...." award in your eyes so I would like to clarify a couple points . First - incomplete-hard to understand questions turn up often enough that it shouldn't turn into this . You did nothing wrong . Not giving a clear description of what your asking about has been done before by many others { yes me also} & will continue to happen I'm sure . Second - Mart hit it smack on the head about LEARNING from this on the answer end & I also agree about the spring-pad gas tank mount to allow some flexing movement . Nothing personal Hope & enjoy your 40 . David J
01-07-2012, 11:16 AM | #62 |
Re: fuel line
Mart you got it on the gas tank mounting spring. These frames twist and bend a lot. If you jack up a convertible or put it on a lift that picks the car up by frame pads you can't open or close the doors. If the tank was bolted solid to the frame the bolt holes would tear out or the tank would crack. The radiator is even more tender having soft metal and soldered parts. G.M.
www.fordcollector.com |
01-07-2012, 11:50 AM | #63 | |
Re: fuel line
HEY RYAN!!! Leave it.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 01-07-2012 at 01:31 PM. |
01-07-2012, 12:30 PM | #64 |
Re: fuel line
I'm not sure if I understand everything I know about that
Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" - Henry Ford |
01-07-2012, 12:36 PM | #65 |
Re: fuel line
"FUEL THE FIRE" will ya OLD HENRY, O.K. more. more.
01-07-2012, 01:15 PM | #66 |
Re: fuel line
Is there a preferrable "fuel line fitting" to use for "fueling the fire?" And, does anyone have any opinions about any kind of sealant to use on such fitting? (I love this thread.)
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 01-07-2012 at 01:36 PM. |
01-07-2012, 01:35 PM | #67 |
Re: fuel line
Lol
01-07-2012, 03:34 PM | #68 |
Re: fuel line
01-07-2012, 04:04 PM | #69 |
Re: fuel line
Pipe dopes! (Get it?)
(See #40) (Keep it commin')
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
01-07-2012, 04:05 PM | #70 | |
Re: fuel line
Yeah I fitted the tank in mine on uneven ground ,My brother in law was following me when I did a right turn the inside wheel lifted of the ground ,when I went to town the only way i could get the door open to get the Misses out was run one wheel up on the curb .LOL
01-07-2012, 04:30 PM | #71 |
Re: fuel line
It was fitting for me to have a flare for such dopes! (kinda corny)
01-07-2012, 05:26 PM | #72 |
Re: fuel line
Now the puns are getting reminiscent of "Laugh In" with Goldie Haun and Rowan and Martin back in the 60's. Sick. Really sick.
01-07-2012, 09:24 PM | #73 |
Re: fuel line
Mart i dont know what sealant i got on the threads, i'm totally confused now.
01-07-2012, 09:26 PM | #74 |
Re: fuel line
On & On it goes.........................
