12-01-2014, 07:46 PM | #61 | |
Re: 1933 can't start after recent restart
Thanks for your help. |
12-01-2014, 09:40 PM | #62 | |
Charlie Stephens |
12-01-2014, 09:52 PM | #63 | |
If I have to set the gap between the points is that a simple thing to do? Do I need a special wrench or only a screw driver? |
12-01-2014, 10:13 PM | #64 |
Frank,
I might suggest if you have never gapped points before, you should have someone around that has. I appreciate your tenacity to do this yourself...but sometimes you really need a better trained eye that get things one the right track. Good luck, and may she run soon! |
12-02-2014, 06:05 AM | #65 |
Frank,
Please don't go looking for a resistor under the dash or anywhere else on the car. There wasn't one on your four-cylinder car originally and there shouldn't be one there now. |
12-02-2014, 08:02 AM | #66 |
They never touched... only slightly moved...approx 0.025 in How much range of movement should there be? 0.015 to 0.0? It may be hard to see the movement difference? In one complete revolution of the engine should the points open and close 4 times? Just curious... the car ran fine for hours several weeks ago... Why would the points have moved apart? If anything after sitting dormant for 20 years you would think their adjusting screw would have been frozen solid??? Seems strange. Last edited by FrankWest; 12-02-2014 at 08:10 AM. |
12-02-2014, 09:13 AM | #67 |
They're not supposed to touch--that's why they are gapped.
12-02-2014, 09:32 AM | #68 |
they are supposed to touch during spark and space after to gap. This is what ignites the gasoline
great site http://modelabasics.com/Ignition.htm Last edited by FrankWest; 12-02-2014 at 09:53 AM. |
12-02-2014, 10:10 AM | #69 |
New Discovery....
As I crank the engine my distributor Cam lobe is NOT turning! So the point gap remanin constant at approx 0.25! I hope the problem can be solved by replacing the Cam Lobe..... Should I ask these questions on the Model A forum? This is a model B engine. I believe the distributor is identical to a model A |
12-02-2014, 11:37 AM | #70 |
You may have a stripped camshaft drive gear
or less likely a bad distributor drive gear. Bob Last edited by Bob C; 12-02-2014 at 12:04 PM. |
12-02-2014, 11:49 AM | #71 | |
12-02-2014, 12:12 PM | #72 |
Frank, you need to pull the distributor to see why it isn't turning. It's more likely that the whole shaft isn't turning, rather than the problem being isolated to the cam/rotor.
Pull a sparkplug and watch the valves* as the engine turns over. Turn it 2 turns minimum. If you can't see the valves moving you may have stripped the cam gear. (*I'm not a 4 banger man, can you see the valves through the plug hole, like you can on a V8?) Mart. |
12-02-2014, 12:21 PM | #73 |
Take off the distributer cap and pull the rotor up and off. The cam is held to the shaft with a screw and if you are extremely lucky it has come loose (probably not). Try to rotate the shaft by hand (it shouldn’t rotate). Next you need to remove the screw in the side of the block (sort of a stud with a screw slot on the end with a lock nut) that holds the distributer in the block. After the screw is out lift the distributer up and out of the block. If you are lucky oil and a hard pull by hand will remove it. Be VERY careful if you try to remove it with hammers, chisels and screwdrivers. The distributer bodies are often stuck in the block and they are easy to break. They make a special puller to remove the distributer (try Bratton’s, (301) 829-9880). There should be a shaft coming out of the bottom the distributer held by a pin, check to be sure it is good. You can see an illustration of the distributer at
http://www.fordgarage.com/pages/bdistributordetails.htm. If everything checks out so far remove the side cover from the block. You can turn the engine with the crank and see if the valves move (meaning the cam is turning). If the cam is not turning the timing gear is probably stripped. If the cam turns there should be a part that fits in a hole at the bottom of the oil gallery with a spring holding it in. Lift off the spring and lift it out. There is a shaft that extends through this piece that has a gear on the end that mates with the gear on the camshaft, check to be sure the gear is OK and pinned to the shaft. If you need distributer parts the best source is probably Renner’s Corner, rennerscorner.com, (734) 428-8424. Post what you find. Charlie Stephens |
12-02-2014, 12:41 PM | #74 | |
Note! The cam lobe does not free spin by hand.. It move approx 5 degrees rotation but does not free wheel. |
12-02-2014, 12:44 PM | #75 |
I have another distributor on my other model B engine. I guess if i eventually switch that and put it in this car I would have to re-time the engine. Right.
I plan to troubleshoot the distributor on my car but just in case I would swap it out for the other distributer. |
12-02-2014, 12:48 PM | #76 | |
And yes to your other question, if you replace the distributor you should also plan on timing it. Charlie Stephens Last edited by Charlie Stephens; 12-02-2014 at 01:09 PM. |
12-02-2014, 12:54 PM | #77 |
Does the dist cam lobe turn when you hand crank the engine?? The cam lobe doesn't turn unless the engine is turned over. The lobe is fastened with the screw on top of it. BEFORE loosening anything turn the engine over with the hand crank with the dist cap off and see if the cam rotates.
Frank I feel for you, I can't remember there've been many threads by you but where are you located?? There may be a "A" guy around the corner from you who would be happy to stop by. Paul in CT |
12-02-2014, 01:32 PM | #78 |
I just looked at dist. and looks like the tang that drives the dist. is pined.
Its could be removed easy, practice on the other engine. Also looks like points are set different gap in low spot. |
12-02-2014, 01:39 PM | #79 |
The cam lobe does not turn,, there is some play approx 5 degrees but otherwise it see attached firmly to the shaft... so i am surprised that iy does not rotate when the engine is hand cranked. If the cam lobe was easily turn by my hand pressure then The shaft could be broken.
12-02-2014, 01:43 PM | #80 |
They have a contical advance that's what moves pull the dist.
