02-09-2014, 02:21 PM | #41 | |
Re: Do I really have to find a spring spreader?
http://www.rigging.net/Turnbuckle.html Here's an interesting video. Notice the small dia. of the rod where it fails. Just imagine what compressive force would be needed if that rod was 1 1/2 in. dia. https://www.youtube.com/watch?v=qeMMTwL-wAc Plus, I have also seen photos of a turnbuckle jack which incurs compression forces in it's use. For example, here''s amotorcycle jack. http://www.faqs.org/patents/app/20100001239 Last edited by 19Fordy; 02-09-2014 at 09:25 PM. |
02-09-2014, 03:19 PM | #42 |
I would, a loaded spring pack stores a allot of energy. If you have a heavy piece of flat stock, angle iron. heavy walled pipe with 1 inch ID, a 1 in threaded rod, nut, heavy flat washer or thrust washer, and a welder you can make one pretty easily. Here is pic of mine.
--------------------------------------------------------------- If it was easy everyone would be doing it /Tony |
02-09-2014, 05:00 PM | #43 |
ok guys go back to post #12, its by dick spadaro, one of the most talented guys on here on these old cars, he tells you how to do it with c clamps,the big american made ones, it works xlnt
02-09-2014, 05:34 PM | #44 | |
Yes, Amen. Don't be scared about this. C clamps work if done with equal parts caution and logic. No don't need a spring spreader. What would you do if the main leaf was reversed? Spreader would be useless. |
02-09-2014, 05:55 PM | #45 |
Gotta read stuff this stuff to realize how dumb you are.....I unbolted all bolts and "let her fly". Wa considerable"sprong!!!!!" but all was ok.
Knuckle Head.
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes.. |
02-09-2014, 06:50 PM | #46 | |
If you ever want to know how to do this operation, let me know.
02-09-2014, 07:54 PM | #47 |
Let me guess...how about 16" of angle, one hack saw, a drill and four bolts? DD
02-09-2014, 07:57 PM | #48 | |
I disagree - it always worked for me
02-09-2014, 08:00 PM | #49 |
Nope, not even close...
02-09-2014, 08:05 PM | #50 |
Well then, that makes at least TWO easy ways.
"If you ever want to know how to do this operation, let me know." DD |
02-09-2014, 08:18 PM | #51 | |
Kube: I am very interested in a reverse eye spreader. All of the speaders in this thread are for traditional non-reversed eyes for the tools rest on at least one of the "curls" of the eyelet. Thanks Tim |
02-09-2014, 08:33 PM | #52 |
the c clamps will work just fine on reversed eye springs
02-09-2014, 08:51 PM | #53 |
Re: Removing a reversed eye spring with a spring spreader.
Something like this will work. Just bend one leg of the angle to fit your spreader. Scroll down to post #8 and 9. http://www.rodsnsods.co.uk/forum/tec...40s-ford-37706 |
02-09-2014, 09:02 PM | #54 | |
02-09-2014, 09:08 PM | #55 |
Wow! I missed a bunch of good discussion today while I was out goofing off. I didn't work a lick on it today (I sure thought about it a lot), but that is only because this is the first sunny day I've seen in a week or so. So the wife and I went over to the beach for a while.
19Fordy - I would love to take some copious notes and even do some video of the gear change, but I'm actually handing this job off to someone that knows what the hell they are doing. (Unlike me.) And they are out of town so I probably won't be able to even watch the process. Actually, I'm not really afraid to tackle most jobs and I do have a pretty well equipped shop for a hobby. Unfortunately, a shop press has not found its way to my shop. Yet. I may try it when I get to the '35 truck. I really just want to get this '36 safe and sound and drive it right now. As to the ebay spreader, I took it as just a suggestion of the things that are out there to consider. I am interested in the reverse eye spreaders for anyone wanting to share.
Do I look like I have a plan B? |
02-09-2014, 09:09 PM | #56 |
Ha! Ha! DD, you submitted that while I was typing!!
02-09-2014, 09:12 PM | #57 |
02-09-2014, 09:28 PM | #58 |
02-09-2014, 09:46 PM | #59 |
The same guy that sells the model A spreader also sells one for 32-48 Ford Model B 18 48 Front Rear spring spreader Lincoln Mercury Coupe Sedan. Here is the link. http://www.ebay.com/itm/150786515709...84.m1497.l2649
John Live for today, but save for tomorrow! |
02-09-2014, 10:21 PM | #60 |
Harms way did a tech step by step on the hamb, (think he posts here to) on taking a reverse apart to install/remove. Some good suggestions also in wrapping the spring with a chain or something if the clamps move.
http://www.jalopyjournal.com/forum/s...d.php?t=646689 Another on reverse eye spreader ideas. Go down to around post 11. I was looking for the one on the cradle adaptor version that petejoe mentions in is this thread. Maybe that was a fb post? Still looking... http://www.jalopyjournal.com/forum/s...pring+spreader |
