Old 07-05-2012, 03:16 PM   #21
tbirdtbird
Default Re: Rear end advise/suggestions needed!!!
Tbone, that hole worn thru the axle tube can be welded easily, have done it a few times. do not discard that tube
'31 180A
tbirdtbird is offline   Reply With Quote
Old 07-05-2012, 03:20 PM   #22
tbirdtbird
Doug, why braze? It is soft and will pound away easily. If you can do all I see in the pics I know you can MIG or TIG
'31 180A
Old 07-05-2012, 03:54 PM   #23
oldmanandakid
oldmanandakid's Avatar
Doug in NJ would you mind detailing the process for riveting the replacement front roller tracks as shown in your photo gallery3? Maybe we should start a new thread as I don't want to disrupt Banky's flow of information.
oldmanandakid is offline   Reply With Quote
Old 07-05-2012, 04:07 PM   #24
Banky
For now, I'm going to install the new bushing and fill the gap with 2-part epoxy. Most likely JB weld. I do consider this a temporary fix, I'll keep an eye on it. But I figure since there is still metal there, and with the new bushing I should be fine.
Banky is offline   Reply With Quote
Old 07-05-2012, 05:12 PM   #25
tbirdtbird
you are underestimating the forces back there and the pounding that goes on.
epoxy is just that, plastic
'31 180A
Old 07-05-2012, 05:23 PM   #26
Kevin - Illinois
Kevin - Illinois's Avatar
Trying to picture what would happen if that gave way driving down the road. I would assume it would start with a rather loud bang, then other things would happen quickly after.
Kevin - Illinois is offline   Reply With Quote
