Old 04-19-2024, 11:06 AM   #21
Phil Brown
Phil Brown's Avatar
Default Re: Second gear
Originally Posted by nkaminar View Post
Now that the subject of lubrication has been brought up, here is my 2 cents: 600W was good 100 years ago. Modern gear lube deposits a coating on the metal parts that wears instead of the metal. The coating is constantly be re deposited. Use 85W-140 G5 in your transmission.
I wonder how many times 100 years ago someone said " good enough, it'll out last me"
Phil Brown is offline   Reply With Quote
Old 04-20-2024, 10:54 PM   #22
PC/SR
The first diagnostic of any clutch-transmission problem is the depress the clutch fully, and sloooooly move the shifter into 1st gear. If there is interference, ie, some sort of grinding, first check your clutch adjustment at the turnbuckle, then, if there are any cracks, etc on the lever. Then move on to the suggestions above. There is always a tendancy to make things more complicated than they need to be. Sometimes they are complicated, but eliminate the simple first. Most problems are simple. If you are new, do not panic, get advice here or elsewhere.
PC/SR is offline   Reply With Quote
