03-10-2023, 07:28 PM | #21 |
Re: Ugly body dent from rear fender ???
If you are determined to fix this yourself, the best approach is to use a slapper hammer and dolly. Most of the hammering will take place on the outside where you have access. Find a dolly with corner radius that matches the wheel well to quarter corner radius and modify it using a belt sander or disk sander to make the dolly fit down in that corner. You will probably have to make one for each side. There are lots of videos on utube that show how to use a slapper. I made one using a piece of 1/8 x 2 flat bar and pretty much figured out how to use it in a few minutes. Slapper hammers can be found on Amazon, evilbay, Eastwood, and many other sites.
03-10-2023, 08:19 PM | #22 |
both of those dents are just behind where the rear fender brackets bolt to the body. I'd say the car was rear ended, fenders and brackets took the brunt of the damage along with the body. Fenders are easy to replace and probably were without someone repairing the body damage. Enjoy driving your "A" as is unless the damage REALLY bugs you. LRF
03-10-2023, 11:19 PM | #23 |
Thanks for the input guys, looks like another thing to add "if and when" I have the car repainted to original '28 color scheme Arabian Sand. I really thought the fenders were not the correct fit, now with your advice I can relax about finding correct ones, already got 'em.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
03-10-2023, 11:26 PM | #24 |
A couple handfuls of bondo and your good to go.
03-11-2023, 06:55 AM | #25 | |
03-11-2023, 08:59 AM | #26 |
With your enamel paint, a localised hit like this with it's well defined stresses, and the position on the body, a careful PDR will probably pleasantly surprise you.Try to PM me, I have lots of measurements and methods to work on the dent. RDVAARK |
03-11-2023, 10:07 AM | #27 |
not so sure about that. the dent is more then a slight bump- its everywhere. |
03-11-2023, 11:41 AM | #28 |
03-11-2023, 01:27 PM | #29 |
"ronn, 'twas only a joke."
T'were it only so, J. Franklin! Sadly, in our hobby, it's not all that uncommon to find "restored" cars and given-up-on project cars with Bondo slopped in two inches deep in an effort to fill a dent instead of fixing it properly. I have personally dug out deep, cracked Bondo a number of times from Model A and T bodies over the years. Anyone who has been in this hobby long enough could probably match my experience with similar tales of woe - and disgust. 'Sure is cheaper to glob a can of Bondo in a deep dent instead of paying to have it fixed correctly and permanently, isn't it? I'm sure that's the only corner that was cut during THOSE kinds of restorations. I wonder if Packard and Duesenberg restorations have this problem? (written dripping with sarcasm). Marshall Last edited by Marshall V. Daut; 03-11-2023 at 02:03 PM. |
03-11-2023, 02:34 PM | #30 |
J. my apologies. I guess I was out of form.
usually I spot the sarcasm 2 miles away. Today Im running behind the curve. |
03-11-2023, 02:57 PM | #31 |
I would really like to see a few pictures of the entire car. What little I have been able to view leads me to believe, if it were mine, I might not try to fix it.
Enjoy. Last edited by WHN; 03-11-2023 at 03:59 PM. |
03-11-2023, 03:39 PM | #32 |
"...usually I spot the sarcasm 2 miles away. Today Im running behind the curve."
Welcome to the club, the "Behind the Curve" bunch. You are not alone in that feeling here! Marshall |
03-11-2023, 07:26 PM | #33 |
I am working on my ‘29 Phaeton and posted a few pictures of that area of your damage. Not easy to get at the inside without removing backrest if that would be necessary to correct. The back spring locks in over triangular shaped metal tangs located on horizontal wood strips mounted to body. Top of back rest material tacked into tack strip with top material and would be a bugger to mess with. Mine is not dented but have to deal with issues from the rust worm. Body shows evidence of original Balsam Green but am seriously considering another color.
03-11-2023, 08:15 PM | #34 |
I think ADVAARK is right. (Post # 26) I hadn't thought about that but it seems correct. During a rearender, the fenders buckled and formed a fold that pushed in the body.
The paintless dent removal guys can probably do a lot but I think the damage to the starboard side is beyond paintless.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 03-11-2023 at 08:21 PM. |
03-11-2023, 10:18 PM | #35 |
Yooper, your pics show the locations spot-on. I have had the car for 22 years and it was piece mealed together from previous owners. An amateur restoration that I have slowly replaced dozens of incorrect and worn-out parts with restored "28" components. That bend and angle of the rear body will be a doozy to bring back to normal. Someday, when I have found the pot-o-gold to disassemble and repaint it original '28 color scheme, there's a couple pounds of bondo under the seat risers and bottom of door skins. She runs good, though. All brakes, steering, engine/chassis have been re-worked, restored and rebuilt. It is the cosmetics that are still the ugly pig with uneven lipstick!
03-11-2023, 11:11 PM | #36 |
Nice car! Very attractive!
'Just a friendly piece of advice, though: When you repaint your Phaeton after body repairs, paint that chrome windshield frame lower body color. The car will look MUCH more authentic. You'd be surprised how different and better your Phaeton will look with the windshield frame painted the right color. See the photo of our December, 1928 Phaeton with outside door handles and two-tone Niagara Blue Light and Duchess Blue color combo. Marshall |
03-12-2023, 12:48 AM | #37 |
Marshall, yes the windshield FRAME was repainted black, not authentic, but better than bright chrome … thanks!
03-12-2023, 03:06 AM | #38 |
Interestingly, you were so close to being authentic by painting the windshield frame black on your 1928 Phaeton - but you probably didn't know it unless you are a student of the so-called AR Model A's (actually a misnomer, but a handy one)! You were too early in the year to be correct, however. Prototype open cars built in 1927 were fitted with black windshield frames. 'Dunno how many were built that way, but there is at least one surviving photo of a prototype Phaeton demonstrating this, along with a couple other features that didn't make it into production. Windshields in production 1928 open cars were painted lower body color and continued as such into 1929. I have the PPG Concept Acrylic Enamel formula for a very true Rose Beige if you want to have some mixed for spraying. It appears to be an exact match for the color of your Phaeton's lower body.
Marshall |
03-12-2023, 11:07 AM | #39 | |
I don’t see an ugly pig. I see a loved antique car that not matter what, is always going to need attention in one form or another. I would be proud to be the owner. Let other people knock it. They always will, no matter what you do to improve it. Your very lucky. |
03-12-2023, 11:33 AM | #40 | |
