01-12-2021, 10:39 AM | #21 |
Re: Helmet Distributor Rebuild
Sorry, forgot to attach pic...
01-12-2021, 10:48 AM | #22 |
Point plate installed with retainer spring/clip. Now I guess, I need to set the gap. Off the top of my head, I can't remember what it was, but I think it was 0.014?
01-12-2021, 11:06 AM | #23 |
Something is not right. I hear clanking and the "advance" plate is loose. I think someone once mentioned a washer, and not to lose it. I have a flat washer for the crab, but not the helmet. Did I lose it? D'oh...
Crab washer. Last edited by Ziggster; 01-12-2021 at 03:18 PM. |
01-12-2021, 11:08 AM | #24 |
I also installed the helmet advance plate and not the 11A advance plate from the crab. Damn, those retaining clips are a bastard to get off.
01-12-2021, 11:12 AM | #25 |
01-12-2021, 11:18 AM | #26 |
01-12-2021, 11:21 AM | #27 |
There were also instructions neatly folded up. I was about to toss it thinking it was garbage.
01-12-2021, 11:21 AM | #28 |
"Second" page...
01-12-2021, 01:16 PM | #29 |
Replaced the advance plate with the one from the crab. Fits much better although I couldn't even get a 0.006" feeler gauge between the retainer ring and the helmet advance plate. Remember when I said maybe I took too many pictures? Well, the pics I took of the disassembly as well as others have "disappeared". I think it is because my memory is almost full with over 9,000 pics. I found a snapshot I took off of someone rebuilding a helmet distributor in the interweeb, and there didn't seem to be an "extra" washer. I think that washer is specific to the crab style. Back on with the show. Haha!
01-12-2021, 01:28 PM | #30 |
Adjusting the gap. The 1950 FoMoCo instruction sheet said 0.015", or between 0.014" and 0.016". Gap set to 0.15".
01-12-2021, 01:29 PM | #31 |
Rotor installed. A bit of oil on the other shaft bearing.
01-12-2021, 01:32 PM | #32 |
Guts installed in distributor housing.
01-12-2021, 01:39 PM | #33 |
Interior caps installed. One needed a bit of persuasion.
01-12-2021, 01:40 PM | #34 |
Other side.
01-12-2021, 01:41 PM | #35 |
Oops. Forgot pic again.
01-12-2021, 01:52 PM | #36 |
I think Bubba mentioned using Mobiil 1 grease on the vacuum brake cylinder. I don't have any, so I used some Lucas NL GI grease that I had lying around.
01-12-2021, 01:59 PM | #37 |
Vacuum brake tube nut loosely installed as well as brake plunger spring retainer nut. Don't forget the washer...
01-12-2021, 02:01 PM | #38 |
Washer with center hole visible to align with adjustment screw.
01-12-2021, 02:03 PM | #39 |
Adjusting screw with locking nut installed. I have no idea what pressure or tension is needed.
01-12-2021, 02:05 PM | #40 |
Ignition coil gasket. That was tough. Lol! Much thicker than the original. I wonder why?
