08-14-2019, 01:47 PM | #21 |
Re: 1932 ford frame differences
Sorry, my post was to indicate you indeed asked in the right forum, even if I didn't know your answer.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 08-14-2019 at 05:46 PM. |
08-14-2019, 02:01 PM | #22 | |
So DavidG.... so what you are saying is that.... all 32 frames in the US would have had the reveal design on the frame rails? Just making sure I am following - and thanks to all for chiming in on this. It's greatly appreciated.
08-14-2019, 03:14 PM | #23 |
08-14-2019, 03:22 PM | #24 |
The only other thing I can think of is a very small number of frames without the K member legs.
But the vast majority of frames are run of the mill, swaged rails, k members fully equipped, various strengtheners at the rear. It's worth mentioning that for most frames, there is no difference between a V8 and a 4 cyl frame, either motor is compatible. Just ask away, good people here, with a lot of knowledge. Mart. |
08-14-2019, 03:32 PM | #25 |
08-14-2019, 05:35 PM | #26 |
The initial leg-less center cross member was one of the three major versions that I cited in #9 above. There was a service campaign to add the legs, but it wasn't 100% effective as a handful of frames survive without them, including the two shown in the photos below. |
08-14-2019, 08:24 PM | #27 |
08-14-2019, 10:02 PM | #28 |
Oh, and welcome to the Barn!
08-14-2019, 11:47 PM | #29 |
in the end, I am most interested about the length, width and whether or not all 32 frames had the reveal on the frame rails or if some did not have the reveal design.
08-15-2019, 07:32 AM | #30 |
As David and others pointed out, no dimensional changes except minor stuff like the addition of the reinforcement on the outside of the frame (not common, so a non-issue). All U.S frames have reveal.
08-15-2019, 08:15 AM | #31 | |
08-15-2019, 09:28 AM | #32 |
Evobuilder; To answer your question. Yes all '32 passenger, pick-up, and station wagon basic frames are identical it length, width. They all have the lip on the bottom, and the reveal where the front fender bolt to the frame.
As all the discussion about early, mid year and late frames are correct, but the dementions remained the same. The 4 cylinder cars vin numbers began with B-500,001. The V-8 cars were stamped beginning with 18-000,001. But the frames were identical. Welcome to the Ford Barn. |
08-15-2019, 09:47 AM | #33 |
bluardun,
A minor difference; the V-8 engine numbers in production vehicles start with 18-1, which Henry Ford stamped himself, complete with an upside down figure 8. |
12-30-2020, 01:02 AM | #34 |
David, I think I may have asked you this once before but the old memory isnt up to OEM standards...
I have an early frame which has been "farmer engineered" after having the frame crack over the rear axles. Can I make up reinforcing plates and then spot weld and perimeter weld them to the inside? Can they be flat or would they need a top and bottom flange? The car will be full fenedered slightly rodded so could outside reinforcements be ok as well? Thanks in advance... Last edited by Fortunateson; 12-30-2020 at 03:08 AM. |
12-30-2020, 07:06 AM | #35 |
Fortunateson,
Boy, I sure can relate to your OEM memory reference! Both the short-lived outside and the subsequent inside reinforcing plates were formed with flanges, top and bottom. Necessarily, the rear cross member was shortened slightly to accommodate the thickness of the inside reinforcement plates. |
12-30-2020, 07:10 AM | #36 |
Were differences in the steering box holes considered? (More upright steering column in pickups.)
12-30-2020, 08:01 AM | #37 |
For most of the '32 model year the three bolt holes in the frame rails for the attachment of the steering sector housing were round and the hole location in the steering sector housings differed to accommodate the two different steering column angles. Late in the model year the need for two different sector housings was eliminated by slotting the three holes in the frame rail. The sector arms remained unique for the two different column angles.
12-30-2020, 09:01 PM | #38 |
Thanks David. Now what was it I was asking about....? LOL. If I make my own would the flanges be required? Considering our modern roads and not the old roads/farmers fields would plates be ok? Also thinking of Boxing the frame over the rear axle as an alternative.
12-30-2020, 09:22 PM | #39 |
As your not concerned about being 100% original, boxing might be the best approach.
10-29-2023, 05:34 PM | #40 | |
