Old 06-30-2014, 02:39 PM   #21
Bassman/NZ
Bassman/NZ's Avatar
Default Re: !939 spun #2 rod bearing
Originally Posted by Bruce Lancaster View Post
The early engines with insert rods were wartime canadian and British, and I think used rods capable of taking the floaters.
I suspect that some 59's, probably post-1948 production replacement engines, used the late crank and rods Don't know for sure.
This is what I have. A C59A Canadian engine that came with insert bearings, but thick ones, not the thin 8BA type. Those thick shells seem to be made of unobtanium, so I've changed to floaters.
Bassman/NZ is offline   Reply With Quote
Old 06-30-2014, 03:05 PM   #22
Jim
What leads you to believe that you have a spun bearing? with the engine still intact. Jim
Jim is offline   Reply With Quote
