12-29-2023, 02:31 PM | #21 |
Re: will not idle
You can hot wire it to aid diagnosis and thus eliminate the pop out and ammeter as possible culprits. Diagram here
12-29-2023, 10:52 PM | #22 |
Re: will not idle
mine would not either after sitting for 10 years.checked fuel system rebuilt carb no luck.pop out ignition was the problem.replaced it with a new one and fired right up and idels great.
05-07-2024, 11:50 AM | #23 |
Re: will not idle
I have a New Idle Question in this thread about idle problems.
Engine starts easy, runs well, idles a low enough RPM sound. But, when I let OFF the accelerator for shifting, after revving the engine, or other reasons to "throttle down" the RPM and engine take an inordinate amount of time to reach the idle speed/RPM. Like 5-10 seconds once accelerator pedal is released until engine reaches idle speed. Is it as simple as I have forgot to lubricate a linkage somewhere? The carburetor was rebuilt by a knowledge member of my club and the car always starts immediately and she purrs. So, I am fairly sure the carb is not the problem. The only issue is, it takes a while to reach idle speed once pedal is released. Any thoughts? Thanks, Fast-Revving-n-the-Smokys |
05-07-2024, 01:06 PM | #24 |
Re: will not idle
Check the linkage assembly on the backside of the engine, it has two hole holes , also the return spring may be weak or partially broken.
BTW it ok to start a new thread, some people won’t respond to old threads
05-07-2024, 01:16 PM | #25 |
Re: will not idle
Big Hammer, thanks for the experienced tip. I appreciate it.
I am new and learning, only owned a Model A for a few months. I started a thread one time and I received several hotlinks where "something similar to this has been discussed elsewhere". I am just trying to go with the flow and acquire some of the valuable info from all you smart and experienced guys. |
05-07-2024, 05:31 PM | #26 |
Re: will not idle
05-08-2024, 06:52 AM | #27 |
Re: will not idle
I do not know. I think it is the stock fly wheel. Everything else on her is stock. How would one determine that?
And, what are u thinking? |
