12-07-2016, 10:55 PM | #21 |
Re: Are all new 2 blade fans in the catalogs alike?
Four blade fans where for commercials as they went slower & more likely to overheat when going slow hauling a load , If fitting the alloy 2 blade don,t forget the steel washer under the nut, this will keep the blade tight on the taper.
12-07-2016, 11:01 PM | #22 |
After an original steel fan broke apart and nearly tore apart my radiator, I will never use or recommend using an original fan of any sort.
12-07-2016, 11:14 PM | #23 | |
All steel from pedal to wheel |
12-07-2016, 11:43 PM | #24 |
Installed a new Snyder alum. fan on a new leakless pump. The castle nut provided with the pump wouldn't align with the cotter hole with a washer installed. The vendor's catalogue dwg. shows no washer but not sure if that's for a steel fan. The fan appears to fit the shaft and woodruff key very well and snug. Should a very thin steel washer still be used under the nut ?
12-08-2016, 12:16 AM | #25 |
yep, for sure if the fan is aluminum.
Using the side of your grinding wheel just lightly grind on the nut a little at a time until you can get the cotter pin thru
'31 180A |
12-08-2016, 01:55 AM | #26 | ||
12-08-2016, 09:09 AM | #27 |
12-08-2016, 09:29 AM | #28 |
Are your fans newer? Or purchased from some flea market table selling old stock...
12-08-2016, 11:49 AM | #29 |
Okay thanks for the info. A thin washer makes sense.
12-08-2016, 12:23 PM | #30 | |
12-08-2016, 07:35 PM | #31 |
Why not just keep it simple and reliable, and install a new 2 blade aluminum fan?
12-08-2016, 09:05 PM | #32 |
Macs has two different two blade fans, one cast aluminum and one steel. I have the cast aluminum but haven't got it on yet, still have the original.
12-08-2016, 10:51 PM | #33 |
PLEASE, don't ANYONE ask about WHICH OIL????
Bill W.
12-08-2016, 11:20 PM | #34 |
I store my unused 4-blade fans wiped down with non-detergent oil
'31 180A |
12-09-2016, 08:40 AM | #35 |
I would definitely add some marvel mystery oil to the mix.
12-09-2016, 08:52 AM | #36 |
Since this thread has already gone all over the place I'll put in a plug for the six-blade plastic fan, if you don't insist on the original look.
12-09-2016, 09:37 AM | #37 | |
Seriously, One was bought at a swap meet and the other was was purchased from Snyders two years ago. Terry |
12-09-2016, 12:37 PM | #38 |
That is what I now have after the 4-blade "truck" fan that came wiht my vehicle took out my radiator when the rivets decided to self destruct.
Alaskan A's Antique Auto Mushers of Alaska Model A Ford Club of America Model A Restorers Club Antique Automobile Club of America Mullins Owner's Club Last edited by CarlG; 12-09-2016 at 12:56 PM. Reason: spelling |
12-09-2016, 12:41 PM | #39 | |
12-09-2016, 12:55 PM | #40 |
Dick Steinkamp, Post # 37: "Anyone who uses otherwise would be a fool! "
------------------------------------------ Dick, I am hoping that you are having a little fun and humor with us, with that remark. Otherwise it might be construed as being rude, and not in keeping with respect for other's view points. |
