10-29-2020, 10:31 AM | #21 |
Re: Source for epoxy-filled 6 volt coil ?
The Pertronix epoxy-filled coil arrived yesterday and is now installed, and the car runs great.
The coil I swapped out was a Ford-script reproduction - looked almost exactly like an original SP coil except the screw terminals are straight not slanted. It is an oil filled coil.....so why would it be sold without a warning to not install upside down ?? I plan to carry the original tar-filled SP coil I have as a spare - not the modern repro. |
10-30-2020, 02:11 PM | #22 |
I just bought a Pertronix Epoxy coil from Amazon.
10-30-2020, 03:21 PM | #23 |
Purdy,
I want to order one for my 29 Roadster - 6V. Just looked at the site and it didn't look like there was a diffent one for 6V vs 12V? Am I missing something or will it work on 6 or 12 volt?? Thanks, Jim |
10-30-2020, 08:22 PM | #24 |
Do not buy one from the big supply house's they are junk..been thru that ..get a old 50's coil and clean it up ..sc
10-30-2020, 09:21 PM | #25 |
I just bought the 6V coil mentioned in post #4. So far, it’s working quite welll.
10-31-2020, 07:36 AM | #26 | |
You can get it right from Petronix. 1.5 ohm. Make sure to get epoxy filled. |
10-31-2020, 04:47 PM | #27 | |
Jim , I use the twelve volt version . I got mine from Amazon but they can be purchased from Auto Zone , Advance Auto , Pertronix or most parts houses The six volt version will probably need to be ordered .. You can google Pertronix for more information . |
10-31-2020, 05:57 PM | #28 |
I ordered mine through Summit....They have a warehouse in Reno so things get here in just a couple of days..
https://www.summitracing.com/parts/pnx-40111 .
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
