06-28-2017, 07:18 PM | #21 |
Re: Rare '40 convertible restoration project
Maybe we went over this before but like Jason in TX I am wondering what cowl tag do you have, maybe a picture of it. My 40 convert project (for sale in the swap forum) has nothing like that.
I am CERTAIN your car will be stunning! And yes, you already have put LOTS of time into it. |
06-28-2017, 08:21 PM | #22 |
@Kube
My good friend is a custom modeler and will spend hundreds of hours building a model.......he said the first step to rehabilitation is recognition!!!!! Nice car and great work so far. |
06-28-2017, 09:04 PM | #23 | |
The heads do not have Mercury upon them. They do have the "T" on the face of them, as do all 1940 Mercury heads. On the top "side" are the part numbers typical of all heads. these of course are 99AS 6049 and 6050. I have documentation that dictates this was a special order car with the Merc engine. If anyone is so interested, I would explain the process that was necessary to acquire a '40 Ford built in this fashion back in the day.
06-28-2017, 09:08 PM | #24 | |
Many folks as you surely know have their OCD manifested in much less productive ways, like washing their hands 200+ times per day (example). Like I said... I am fortunate that mine manifested itself in to something I enjoy so much.
06-28-2017, 09:25 PM | #25 |
Was the tag in the upper LH part of the firewall near the top. there are 3 tiny holes that never had any drive pins in them up there on my convertible that have Mandarin maroon paint in them. I vaguely remember asking you about these holes in the past. These holes are above where the wiring comes through the firewall. the 2 holes most inboard of the car are exactly 1/2" apart then the other hole is exactly 2" outboard of the outboard most hole of the ones that are 1/2" apart. All 3 of these holes are in a line parallel to the floor or I guess level. Under close examination, the holes appear to have original paint in them.
No number under the V reg like my woodie cowl either. Maybe this was a Friday car and missed the tagging. |
06-28-2017, 09:57 PM | #26 |
__________________ Sounds like your a glutton for punishment. |
06-29-2017, 07:21 AM | #27 | |
I can still recall as a youngster thinking as how the forty coupe was the coolest thing ever made. I loved the tudor as well. One Sunday while pedaling my bike, as I rounded a bend I spied a convertible for the first time. In my excitement I approached the driver to see if he would be interested in making some kind of deal. Turned out he was just borrowing the car and took his two girlfriends for a ride but was now stuck with steam rising from the radiator. Anyway, to shorten the story as I walked behind the car and viewed the trunk lid, I thought, 'a drop top is nice, but not the excellence radiated by the coupe'. Oh welll... Kudos for tackling this hiccup. It certainly wasn't a small task.
Enjoy yer day. Tom Hate can't fix what it started. |
06-29-2017, 07:59 AM | #28 |
I applaud you for bringing back history one car at a time.
06-29-2017, 08:02 AM | #29 | |
Of course I can't say with any proof what actually transpired in the various assembly plants on any given day. We all know these cars were mass produced at a quick rate. There is no doubt many things that were supposed to happen were overlooked or simply ignored. The dimples you describe on your firewall are exactly what were utilized to locate and attach these tags. I have attached a photo of the tag that was present on my (former) Merc equipped Ford coupe. This tag, the matching serial number, trans number and title number offer only more confusion. I was never able to figure out what the "PC" was. Nor was I able to find anything in the Archives in this respect. The stamped numbers in your firewall have been witnessed on other cars as you certainly know. They have been witnessed on closed cars as well as wagons. So, what does that mean? I think it is obvious that no definitive process was strictly adhered to in 1940. I firmly believe we will most likely never know with certainty what the tags and stamped number process was supposed to have been.
06-29-2017, 10:28 AM | #30 |
Since you had that tag on a coupe with a merc engine and a convert with a merc engine I wonder if the tag was a notification to the assembly personnel that there was an exception on this vehicle to be checked on a build sheet travelling with the car ie different engine? I haven't seen a tag like that on any other 40. I agree with you, we probably will never really know for sure. Thanks Mike. There is no doubt this convertible will be special. What color was it originally?
06-29-2017, 10:33 AM | #31 | |
The engine in one has aluminum Canadian heads with a 4 barrel intake and headers.The modifications to the engine was done before 1968.
Milt/Las Vegas |
06-29-2017, 11:00 AM | #32 |
Kube,
When it's done I'll treat you to the first tank of petrol ! (gas in your language)....PROMISE ! |
06-29-2017, 06:08 PM | #33 |
PC could have meant a lot of things. Production Code, Production Change, or Police Car just to name a few. What it actually means doesn't matter as much as just having it correct for all it had in its original form.
It looks like you have worked a lot of the issues with the body out so far. Sticking to schedule, your likely not to far off from the goal you set. This will certainly be an interesting project to finish up. |
06-29-2017, 08:16 PM | #34 | |
The tags I have seen on convertibles simply indicated body number. I have attached herein the tag from this car. Another oddity I have noted is that this car and the one I knew of in New York both had "99" stamped in to the firewall, my coupe did not. The "99" stamp would in my opinion be the "note" to the assembly line worker to install the Merc engine. What do I know? Not much when it comes to these Merc powered Fords. it seems there was not much of a definitive method of production. This car was built Lyon Blue and shall be once again.
06-29-2017, 08:18 PM | #35 | |
06-29-2017, 08:21 PM | #36 | |
I will build this exactly as the "build letter" showed it to be ordered. No radio nor heater will make it kind of odd for a convertible as it seems most seen at a show these days are loaded with accessories. The "build letter" did not call out for either so this car won't be getting them. The letter did not specify tires. I am still on the fence as to what I might install. They will be the optional 6:50 but whites or blacks?
06-30-2017, 09:58 AM | #37 |
Kube, If I were closer I'd love to come help you and learn at the same time. I have the feeling though that you would kick my ass out of the shop! Project looks good so far. Hopefully we get to meet up in Dearborn.
06-30-2017, 01:21 PM | #38 |
First class work Kube ,it will be all worth it in the end .Ted
06-30-2017, 08:19 PM | #39 |
Kube
In 1935 ford had a Phaeton coupe, why not in 1940? Bruce
Works good Lasts long time |
07-01-2017, 12:26 PM | #40 | |
Milt/Las Vegas |
