Old 05-02-2016, 06:53 PM   #201
Vanspeed
Vanspeed's Avatar
Default Re: 1941 Ford Pickup frame-off restore for the next generation
Originally Posted by ken crans View Post
i can't believe you got that in the back of a sport trak..lol
x2!
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 05-02-2016, 08:03 PM   #202
mrfliboy
mrfliboy's Avatar
Ford on Ford, works for me.
mrfliboy is offline   Reply With Quote
Old 05-02-2016, 08:18 PM   #203
bfoley
bfoley's Avatar
Glad you made it back without losing anything. I like the pic you took outside Preston's Garage. I'll have my '66 there taking some pics this summer hopefully.
bfoley is offline   Reply With Quote
Old 05-03-2016, 06:56 PM   #204
mrfliboy
mrfliboy's Avatar
It was great meeting the gang. Appreciate all the help loading. The trip home was smooth as silk.
Took off 1/2 day Monday and was able to strip it and lay it on my frame. Lined up perfect.
Tell all many thanks. Look forward to seeing your '66
Old 05-15-2016, 05:18 PM   #205
mrfliboy
mrfliboy's Avatar
Cab Day
Got 3 buddies, to help throw it on,
a little fudging
6 bolts later and mounted cab.
Old 05-23-2016, 05:29 PM   #206
mrfliboy
mrfliboy's Avatar
Wiring of voltage regulator.
Moving right along but spring/summer slows progress a bit.
Any one have the bat/arm/field location on the reg?
I'm guessing pass side is Arm
Middle is Field
Driver is Bat
Can find no identification on it.
As always thanks in advance!
Just fired the truck and wiring is correct!
Old 06-09-2016, 11:04 AM   #207
mrfliboy
mrfliboy's Avatar
Question for all the Ford folks, just found out there is some sorta box, that the ignition switch terminal plate body and brush set goes in. Any one have pics or something that will work, available???? Or is it necessary?? As always thanks in advance.
Was able to purchase a setup from a fellow barner. Thanks
3yrs into rebuild: https://youtu.be/tSLQBYInGQo
Old 07-03-2016, 08:09 PM   #208
mrfliboy
mrfliboy's Avatar
Got my hood mounted and adjusted, took a full 6 hrs.
I mounted the hinges to the cowl 1st, than hood to hinges.
Removed and tweaked the drivers side hinge, over 1/4".
When adjusted just right, tightened the cowl mounts up.
Springs were last, big old broom stick propped up the hood.
Very happy with final gaps.
Hoping for another good day tomorrow.
Fenders and all went just fine.
Old 07-03-2016, 08:26 PM   #209
JSeery
JSeery's Avatar
Looking good!
Old 07-03-2016, 08:52 PM   #210
Tinker
Tinker's Avatar
Like the color. Looks very nice.
Was there a reason you didn't paint the engine? Just curious, not a big deal or anything.
Old 07-03-2016, 10:31 PM   #211
41panelmark
41panelmark's Avatar
Wow! very nice, it sure looks good!!!
41panelmark is offline   Reply With Quote
Old 07-04-2016, 07:56 AM   #212
Ken Crans
Ken Crans's Avatar
Coming out very nice...
Ken Crans is offline   Reply With Quote
Old 07-04-2016, 07:57 AM   #213
mrfliboy
mrfliboy's Avatar
Originally Posted by JSeery View Post
Looking good!
Thanks
I wanted to keep the drive train original, leave the painting for the next generation.
Thanks I can actually see a little light at the end of the tunnel.
Old 07-04-2016, 07:59 AM   #214
mrfliboy
mrfliboy's Avatar
Thank ya. Fenders went well, got the gauges working
https://www.youtube.com/watch?v=hDgEdsXV6kE
Old 07-04-2016, 07:52 PM   #215
bfoley
bfoley's Avatar
Coming along! What is the switch on the steering column for?
Old 07-04-2016, 08:13 PM   #216
mrfliboy
mrfliboy's Avatar
Ignition on. The key unlocks steering wheel, allowing switch to on position.
Sent from my XT1254 using Tapatalk
Old 07-06-2016, 01:37 PM   #217
40fordpu
40fordpu's Avatar
Following. Truck looks amazing!. I am inspired to get out in the garage now! I am at the stage of rust repair. Little hesitant since my skill level is beginner. Going to buy pre fabriated panels. Any advice?
40fordpu is offline   Reply With Quote
Old 07-06-2016, 01:40 PM   #218
Tinker
Tinker's Avatar
WoW!
Old 07-06-2016, 06:13 PM   #219
mrfliboy
mrfliboy's Avatar
Thanks
Think it out ahead of time is all. I started underneath where no one could see .
I heard mixed reviews on pre fabs. So I bought a bead roller so I might've broke even over all.
Have fun is all.
Old 07-06-2016, 06:14 PM   #220
mrfliboy
mrfliboy's Avatar
Thanks, It feels good after 3yrs. Always fun putting bling on.
