Old 02-10-2014, 01:46 PM   #1
Gold Digger
Question Mystery
For the last 3 years every Sunday evening after church I drive my roadster pickup to visit my mother that lives in a rest home. I drive a 60 mile round trip. For the last 2 years on my way back home the engine pops and dies with in 100 yards of the same place every Sunday. I have drained and cleaned the gas tank, I only buy gas with out ethanol, I keep it tuned up good. All I have to do is loosen the strained on the zenith carb and let a small amount of gas run out and it always has plenty of pressure there but never have any rust. I screw it back and climb in and resume driving at 40 to 50 mph. Haven't missed a Sunday in two years.
Gold Digger is offline   Reply With Quote
Old 02-10-2014, 01:50 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Mystery
Is that place close to a N.S.A. or other Govt. installation?
Old 02-10-2014, 01:50 PM   #3
Tom Endy
Tom Endy's Avatar
Default Re: Mystery
Check that the vent hole in the gas cap is open.
Tom Endy
Old 02-10-2014, 04:32 PM   #4
Chris Haynes
Chris Haynes's Avatar
Default Re: Mystery
Tom Endy
Yup. Sounds like the vent is plugged. Creates a vacum and gas can't flow, When you open the cap the vacum is gone and you toodle do home.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-10-2014, 05:34 PM   #5
V4F
V4F's Avatar
Default Re: Mystery
are you near area 51 ?
V4f
V4F is offline   Reply With Quote
Old 02-10-2014, 10:08 PM   #6
Gold Digger
Default Re: Mystery
No government installations near here and the gas cap is so lose it worries me it might rattle off sometime. Still a big mystery to me.
Old 02-10-2014, 10:22 PM   #7
Ted Duke
Default Re: Mystery
Golddigger,
I once had a friend whose car would drive fine for awhile and then QUIT. He would coast to the side of the road, and sometimes it would start right away, and sometimes not for awhile. Long story short, PING-PONG ball in gas tank, he had po'ed some neighbor kids.
Ping Pong ball, unlikely. Old soggy cork float? Piece of something else?
Ted
P.S. I also had the same problem with a 1971 VEGA (Motor Trend Car of the Year) built like a tank, but shoddy workmanship and NO design, but that problem was a loose wire that caused a perceived low oil pressure to cut the fuel pump off.
Ted Duke is offline   Reply With Quote
Old 02-11-2014, 07:40 AM   #8
Richard Wilson
Richard Wilson's Avatar
Default Re: Mystery
Back in the 50's my little brother put a little crab apple in Dad's Model A gas tank. Drove dad crazy for about a month before he figured it out.
Richard Wilson is offline   Reply With Quote
Old 02-11-2014, 08:22 AM   #9
jm29henry
jm29henry's Avatar
Default Re: Mystery
is it hilly in this area maybe check float level maybe this hill is it taller or longer than others hills and the float level goes lower for I time where it can catch up .when you stop the carb bowl is able to refill enough to run .you could also try to richen your fuel on your GAV before you get to this point of the road please let us know what you find thanks
jm29henry is offline   Reply With Quote
Old 02-11-2014, 08:56 AM   #10
Afordman31
Afordman31's Avatar
Default Re: Mystery
Years ago my Grandpa bought a used pickup. It would run fine then once in a while it would quit. He would blow a small amount of air back to the gas tank thru the gas line and it would run just fine. Later on it would do the same thing. After pulling the gas tank and flushing it out he found the problem. (Someone had put gas line antifreeze in the gas and the foil that seals the bottle got into the tank. It would float then finally get to the out feed of the tank and plug things up. Afordman31
Afordman31 is offline   Reply With Quote
Old 02-11-2014, 11:00 AM   #11
29Cabriolet
29Cabriolet's Avatar
Default Re: Mystery
The theories of some foreign material in the tank sound most plausible. But why within 100 yards of the same place? And why only on the return trip?
29Cabriolet is offline   Reply With Quote
Old 02-11-2014, 01:24 PM   #12
mleder
Default Re: Mystery
Put a little more in the collection plate,it's just a someone trying to get your attention since it only happens after Church.
mleder is offline   Reply With Quote
Old 02-11-2014, 02:46 PM   #13
whirnot
whirnot's Avatar
Default Re: Mystery
Check your strainer in the tank.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 02-11-2014, 03:14 PM   #14
pat59
pat59's Avatar
Default Re: Mystery
Did you ask your mother if she knew anyone that lived around that place or if that area means anything to her?
-Pat
Ya never know.
pat59 is offline   Reply With Quote
Old 02-12-2014, 12:55 AM   #15
james hitchcock
james hitchcock's Avatar
Default Re: Mystery
I say drive home a different route.
james hitchcock is offline   Reply With Quote
Old 02-12-2014, 06:47 AM   #16
QGolden
QGolden's Avatar
Default Re: Mystery
Is the fuel in the tank at the same level each time it quits? What happens if you fill up at a different time?
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 02-12-2014, 07:17 AM   #17
Gold Digger
Default Re: Mystery
I have rinsed the tank out and checked the screen on the fuel shut off valve. It's not such a big deal to have to stop and bleed the line but I know there is something not right about all of this and I had rather be on my merry way driving. I appreciate all the help I can get on this.
Old 02-12-2014, 07:59 AM   #18
QGolden
QGolden's Avatar
Default Re: Mystery
It is either happening at a certain mileage, or from a certain road condition. 30 miles out and 30 miles back. So say it happens at 40 miles. What happens if you drive somewhere else for 40 miles? What happens if you drive a different route home? What happens if you stay longer or shorter visiting your Mom? Since it happens every Sunday, then it is probably not ambient temp related.
Old 02-17-2014, 10:39 PM   #19
Gold Digger
Default Re: Mystery
Hey all you guy's!! Tom Endy was right about the vent hole. I thought because the cap fit real lose on the tank it would surely vent but I was wrong. I took a air hose and blew through the vent hole and it was stopped at first. I drove the "A" hard Sunday and never had a problem the hold trip. Thanks everyone for the support.
Old 02-17-2014, 10:46 PM   #20
tbirdtbird
Default Re: Mystery
aww shucks it was better as a mystery thriller.....
'31 180A
tbirdtbird is offline   Reply With Quote
