05-09-2024, 12:06 AM | #1 |
1955 Ford Customline Power Steering Filter
Hi I am located in New Zealand and would like to get assistance with oil resivoir filter dimemsions.
Height, ID and OD of filter. Shipping from US to NZ expensive. Hoping to pick up a filter locally which can fit this position. Presently nil filter is fitted! Dont want to continue running without one. Thanks for any assistance. Phil NZ |
05-09-2024, 08:13 AM | #2 |
Re: 1955 Ford Customline Power Steering Filter
Here is a cross-reference for FORD PN AE 33538-A (FILTER - 1954-1956) -
- https://www.oilfilter-crossreference.../FORD/AE33538A Any of these vendors down there? Here are the dimensions - https://www.wixfilters.com/Lookup/Pa...px?Part=108706
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS Last edited by KULTULZ; 05-09-2024 at 08:23 AM. Reason: HELPS WHEN YOU INCLUDE REFERRING URL |
05-09-2024, 03:57 PM | #3 | |
Phil NZ |
05-09-2024, 05:44 PM | #4 |
Have one on the way from a local supplier as per supplied dimensions.
Power Steering Element LF614. Good to be able to source locally!! Phil NZ |
05-09-2024, 07:32 PM | #5 |
I understand that ... $$$ ...
Is it easier for your AUSTRALIAN cousins to source parts? |
05-09-2024, 11:40 PM | #6 | |
Plenty more supply of varoius bits across the ditch. Rubber Connection in Australia caries a good amount of parts. Just got a top radiator hose and ignition switch for 55 Customline from them at a good price plus better shipping rates. Now looking for a rebuild kit for the double action fuel pump. Has the glass bowl at the bottom. Phil NZ |
05-10-2024, 12:46 AM | #7 |
The 'DITCH', I like that.
I forgot about their UTE. Have you been following the thread on pump kits? There has to be a source I would think across the 'ditch' ... |
05-10-2024, 03:38 AM | #8 | |
Belonged to it before so maybe yime to rejoin. Phil NZ |
05-11-2024, 03:54 PM | #9 |
One thing to watch out for and that is filter size. The early 50's cars used a bigger filter than later cars (No idea of the cutoff). Using the later, smaller filter in a car that used the larger filter may cause leaks . I know of a few friends with early Birds had this problem.
