05-02-2024, 06:00 PM | #1 |
1954 Mercury underhood question
My 54 Monterey has a hood prop rod that holds the hood open. It looks like it has been there a long time. Did they come with those rods, or is this something someone added along the way??? Gives me alot of head room
Bob from Northport Northport, Michigan |
05-02-2024, 07:08 PM | #2 |
Re: 1954 Mercury underhood question
No hood prop for a 54 mercury from the factory if it's the same as my 54 Ford. 54's had very poor hinges plus you may be missing some springs at the hinge. There are two, one a typical coil and a small flat coil type spring. on both sides.
05-07-2024, 05:17 PM | #3 |
There’s someone I found that remakes these hinges better than the weak originals. They are fairly expensive - around $500 per pair at the time. I put them on my Merc and they are good.
05-07-2024, 05:41 PM | #4 |
I saw someone mentioned those hinges on a different thread. So far unable to locate the maker
05-07-2024, 06:13 PM | #5 |
I’ll lookup the maker and post it when I get back from vacation in a few days.
05-10-2024, 07:18 PM | #6 |
05-10-2024, 07:19 PM | #7 |
If he still restores..
05-10-2024, 07:30 PM | #8 |
05-11-2024, 08:27 AM | #9 |
Thank You!!
05-11-2024, 10:19 AM | #10 |
You are quite welcome ...
