Old 06-01-2021, 10:04 AM   #1
Ron McIntyre
Default Model A no spark
My 28 A arrived yesterday and started to back off fine. An hour later no start only turn over.Tried the coil wire to head. No spark. Tried a known coil that is good. No spark. New wiring. NOS amp meter. Can anyone help ?
Ron McIntyre is offline   Reply With Quote
Old 06-01-2021, 10:06 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Model A no spark
What type of switch popout etc? all connections tight.
www.whidbeymodelaclub.com
Old 06-01-2021, 10:10 AM   #3
ArtimusGordon
Start here. Open and close the points. No spark check the distributor wiring and condenser! With paper between points check to see if you have voltage on the movable side and ground on the fixed side. If you do move to the terminal block on the firewall and check for voltage readings.
ArtimusGordon is offline   Reply With Quote
Old 06-01-2021, 10:42 AM   #4
jg61hawk
Here is a copy of a post Mike V posted. Please read the entire post.....If it is the junction box ...should be power on both sides. If not the Amp gauge is bad. Jump across the two lugs of the junction box to bypass meter....
Default Re: Coil problem?
Mike V Florida has posted this and I think it's wonderful:
This is my generic no spark troubleshooting list,
No Spark
Some possibilities are:
1.Blown or defective fuse (use of a fuse is an aftermarket item)
2.Bad connections at ammeter, or ammeter itself (t0 find out put a jumper wire from one post of the terminal box to the other to take the ammeter out of the circuit temporarily)
3.Bad ignition switch and/or cable, or loose cable connection at the switch.
4.Loose or broken wires at bottom of coil
5.Loose or broken wires inside terminal box
6.Loose, bare or broken pigtail wire under distributor plate, or wire grounding to plate or distributor body
7.Points not opening, or point arm grounding to cam due to worn rubbing block
8.Worn electrode in underside of distributor cap
9.Loose or broken high tension wire from coil to cap
10.Condenser burned out or grounding (some condensers are too long and can touch the distributor body inside)
11.Weak coil
12.Rotor not turning due to loose cam screw or bad timing gear.
Ok now break out a volt meter (a light bulb can give false readings).
Start at the fuse block, you should have voltage on both sides of the fuse. If you only have voltage on one side, replace the fuse or fuse block.
Now with voltage on both sides of the fuse, move up to the junction box. There should be voltage at both terminals. If voltage is present only on one side the problem is at the ampmeter and you should Jumper the ampmeter for now.
You should have voltage on both sides of the coil. If not,
remove the red wire on the coil and check again. If you now have voltage on both sides, you have a problem further on. If the voltage is still only in one side you have a bad coil.
Open the points with a piece of paper and remove the condenser. Turn the key on and you should have voltage at the points.
Replace the condenser and you should still have voltage.
If the voltage is missing, remove the top plate and check for voltage on the bottom plate.
Check if the connector from the ignition switch screwed in too far? Do you have voltage on the wire to the upper plate?
Is this wire shorting to ground or broken?
Remove the paper from the points and see that the points are closed. You should not have 0 volts at the points. If you do, the points are dirty or the distributor is not grounded well to the engine.
jg61hawk is offline   Reply With Quote
Old 06-01-2021, 04:06 PM   #5
Anteek29
Anteek29's Avatar
After doing the steps outlined above in #4, please let us know what you find.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 06-01-2021, 09:14 PM   #6
eagle
eagle's Avatar
Check to make sure the points are opening properly. Poor point blocks will wear down and then the points won't open. Lube the cam too.
Old 06-01-2021, 09:33 PM   #7
daren007
Do you own a VOM.
daren007 is offline   Reply With Quote
Old 06-02-2021, 04:42 AM   #8
Rob Doe
Sorry, but I'm having trouble with the last paragraph of the above trouble shooting list. Am I confused?
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 06-02-2021, 11:04 AM   #9
abachman3
abachman3's Avatar
You are removing the piece of paper from the points that you put their to hold the points open and not make a connection. That is part of the testing procedure to see where all of the electrical connections are and which are functioning correctly.
abachman3 is offline   Reply With Quote
Old 06-02-2021, 11:17 AM   #10
jg61hawk
I think there is a mistake a typo...I believe the following is correct
With the points open (paper inserted) there should be battery voltage at all times. With the points closed ( no paper) there should be 0 volts at all times. [ key on].
The posted "you should not have 0" ...I believe should read "you should have 0" .
I did cut and paste the post, perhaps Mike V can join in and clarify...or any others who know a lot more than me! Thanks. Sorry if I spread the wrong info....
Old 06-02-2021, 11:26 AM   #11
jg61hawk
https://www.fordbarn.com/forum/showt...olts+key+on%5D
Read # 6 and then 7 of the attached thread.... Points closed 0 volts would be correct.
Old 06-02-2021, 08:55 PM   #12
Gary WA
Gary WA's Avatar
get it figured out?
Old 03-26-2024, 08:18 PM   #13
Amctavish77
Hi guys new here and thought I’d resurrect this thread since I’m having the same issue and have done all of the above with no success.
A little backstory on this one; 1931 Model A Tudor all stock, ran like a champ until 2 weeks ago. Was cleaning it and apparently the two wires going into the horn (were not hooked up) got jostled around and laid against the back of the headlight (I didn’t catch it) and it arced and burned up the wiring to the headlight and the horn. Easy enough to replace, no super concerned with that BUT the car will no start. It’ll turn over just fine but it’s got no spark; almost as if the car has no power throughout the system.
I’ve done all the tests as outlined in #4 and I am baffled. Any help would be greatly appreciated. Heck, if there’s anyone in the Fresno, CA area that would be willing to help me out, I’d buy you lunch (or dinner)!!
Amctavish77 is offline   Reply With Quote
Old 03-26-2024, 08:28 PM   #14
Marshall V. Daut
If those wires burned up that badly, the wires from the terminal box to the instrument panel most likely are also toast. If they look the least bit blackened or feel crispy, replace them. All the ignition juice runs through those wires, so they cannot be compromised. Pull the terminal box cover off and the instrument panel forward to inspect the wires for signs of overheating and loss of insulation.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 03-26-2024, 08:29 PM   #15
Bob C
Do you have power at both sides of the terminal box?
Old 03-26-2024, 09:13 PM   #16
Amctavish77
Bob: yes, I do have power on both sides of the terminal box
Marshall: I haven’t looked under cover of the term box but wires under the instrument panel look good; no chat whatsoever. I only lost about 6” of wire on the lights and the horn. I’ll pull the cover and report back.
Old 03-27-2024, 08:57 AM   #17
nkaminar
nkaminar's Avatar
The ammeter and ignition switch should be tested under current. Sometimes voltage will pass with no current but high resistance will block the voltage when there is any current. Lots of things to test. Just go through the wiring with a multimeter while the ignition is on and points are closed.
Old 03-27-2024, 12:02 PM   #18
jg61hawk
Easy first step...put a jumper between the two posts on the terminal box...this bypasses a bad amp meter.
Old 03-27-2024, 05:09 PM   #19
Amctavish77
Jumpered terminal box but nothing has changed. I did discover, I have voltage on either side of the fuse with the key in the off position but lose voltage when the key is in the on position. Seems weird or is that my issue. I’ve tested and swapped fuses so I know they’re good. But could the fuse holder be bad?
Old 03-27-2024, 08:51 PM   #20
Amctavish77
I’m losing power at the points. Got power at the terminal box, both sides of the coil and bottom plate of the distributor. Open the points, and I got nothing with and without the condenser (condenser is brand new too). Are the points toast or is there something else causing it?
