10-19-2022, 06:44 PM | #1 |
Do wide 5 rims hold air for tubeless tires
Do the rivets need attention before installing tubeless tires?
10-19-2022, 07:06 PM | #2 |
Re: Do wide 5 rims hold air for tubeless tires
When I bought my '39 p/u with wide fives the PO installed tubeless radials. Don't know if he did anything to the rivets or not. But the rear tires hold air just fine but the front tires loose about 5 psi every week or two. It might be due to the turning stress on the front wheels but not sure.
10-19-2022, 07:10 PM | #3 |
my 37 sat for over 2 yrs and lost about 10 lbs.
10-19-2022, 08:37 PM | #4 |
A wise man always told me that there is no such thing as a tire in need of air....only one in need of repair! Sorry I don't have any information related to your wide 5 rims.
10-19-2022, 09:04 PM | #5 |
Clean the bead surfaces and coat with sealer. No tubes. No problems.
10-19-2022, 09:22 PM | #6 |
10-19-2022, 10:22 PM | #7 | |
Bead blast, then JB WELD dabbed on each rivet is great insurance. They normally don't leak anyway. Coop . |
10-19-2022, 11:22 PM | #8 |
Might work. Give it a try! Some wrap duct tape for tubes to lessen the abrasive nature to the tubes. Probably can't hurt if running tubeless. Or maybe some flexspray to seal.
Suppose it matters how good the "rims" are and what you do. They where not designed to be tubeless. |
10-20-2022, 09:03 AM | #9 |
A number of years ago I bought a set of Coker www 600x16 radial tires with tubes. The valve stems on the tubes were too thin in diameter and would move around in the hole in the rim, causing them to rub, rupture and go flat. I finally decided to try running the radials on the stock rims without tubes and they have held up without any problems.
Imagination is more important than knowledge. |
10-21-2022, 07:48 PM | #10 |
I used Gorilla tape for rim tape on my wide fives.
