07-24-2010, 04:55 PM | #1 |
low voltage rust removal
a couple of weeks ago i read up on this low voltage rust removal , 4volt or so, baking powder or washing soda , clean water , a piece of rebar .
trying to get this right. could one of you attach a link to that thread if you know it ? thanks. |
07-24-2010, 05:57 PM | #2 |
Re: low voltage rust removal
07-24-2010, 09:31 PM | #3 |
Try: www.stovebolt.com go too rust removal. Bob E.
07-25-2010, 12:32 AM | #4 |
So, careful what you ask for? I'l be busy with this for a while. Thanks.
07-25-2010, 02:36 AM | #5 |
I have just given electrolysis a go on some small parts and it works great. I use a 12V 6amp battery charger and a decent splash of washing soda mixed into the water. there's good video's on youtube too. keep the water volume as small as you can and turn the pieces mid way through to get an even clean. good luck.
07-25-2010, 06:28 AM | #6 |
07-25-2010, 08:07 AM | #7 |
I read the wiki article and it seems to me if hi strength and low strength steels are the problem maybe we should forget the process. It even said acid phosforizing removal treatments are bad. I wouldn't want the ears on my carb to break off, or manifold , from engine vibration or even mounting areas of sheet metal. Am I over reacting here? Bill G
07-25-2010, 08:24 AM | #8 |
I personally wouldn't use it on any of my parts since there are less harsh alternatives but the real hazard could be in safety parts such as spindles, axles, steering parts etc.
04-01-2019, 11:28 AM | #9 |
Sorry about this post on an old thread. Somehow I hit the wrong link and I was back in time about 8 years! Time for back to the future again!
I like to use agricultural molasses. It works by chelation, which is worth looking up on the internet. Apparently there are tiny 'things' in the molasses that actually eat the rust. Sounds like snake oil but it works well and does not hurt the metal or make it brittle. Check it out, 'rust removal by molasses' just might work. Another thing, most of these processes work better with a bit of heat but slow down if it is cold. Last edited by Cool Hand Lurker; 04-01-2019 at 11:36 AM. |
04-01-2019, 11:51 AM | #10 | |
It sounds like a great way to remove rust from an engine block or cylinder head. |
04-01-2019, 12:24 PM | #11 |
Additional info on molasses from 2014... you MAy want to investigate before using it.
From what I remember there are different types of molasses and it makes a difference how long cast iron is left in the solution. Different ideas pro and con ... See post #9 ... https://www.fordbarn.com/forum/showt...s+rust+removal Last edited by Benson; 04-01-2019 at 12:36 PM. |
