Old 05-15-2018, 08:49 AM   #1
johnnyford
Default Good morning Ford friends!
Question,
how come when you first start a thread you can add photos?
but after that the option seems to go away?
johnnyford is offline   Reply With Quote
Old 05-15-2018, 09:12 AM   #2
RalphM
RalphM's Avatar
Default Re: Good morning Ford friends!
If you reply, and choose “Go advanced” then you should have another chance to add pics.
RalphM is offline   Reply With Quote
Old 05-15-2018, 10:10 AM   #3
tubman
tubman's Avatar
A lot of times, the photos are too big and the forum won't accept them. It's "hit or miss" thing. I have found the easiest way to make them fit is to load them up in Microsoft "PAINT" (or "PAINT-3D" for you Windows-10 users) and then save them. Make sure you chose ".jpg" as your file type. After I've done that with photos that won't load, I've been able to get 'em in.
Sorry, no help for you "APPLE" types.
Old 05-15-2018, 10:41 AM   #4
Art Newland
Art Newland's Avatar
A little tip on photo size, if you use gmail and take pictures with your phone, an smaller version is saved in the cloud in "Photos". The software that runs the Barn is getting pretty old, more modern versions of it automatically "resize" photos.
"whatever works!"
Art Newland is offline   Reply With Quote
Old 05-15-2018, 10:44 AM   #5
joe plumber
Thumbs down Re: Good morning Ford friends!
Posting photos from a phone on this site is a PITA.
joe plumber is offline   Reply With Quote
Old 05-15-2018, 12:05 PM   #6
19Fordy
19Fordy's Avatar
Following up to what tubman said,
I find resizing photos to 35% using PAINT works fine.
Old 05-15-2018, 12:19 PM   #7
Mart
Mart's Avatar
I put 'em in paint and resize to about 800 pixels wide. Normally works and displays well on the screen.
You out and about driving it already?
Mart.
Old 05-15-2018, 12:52 PM   #8
Charlie Stephens
Hello from an "APPLE" type. Instructions are below:
If it is desired to reduce the size of photos export them at a lower resolution. Go to the command line and click “File” and then from the drop down menu “Export”. The prompts will explain how to export the photos at full size or less than full size to someplace like the desktop.
Charlie Stephens
Charlie Stephens is online now   Reply With Quote
Old 05-15-2018, 03:08 PM   #9
Mike in Mass
Mike in Mass's Avatar
I can post pics on the Hamb ,no problem When I try here ,,Same photo ,,it the luck of the draw .most of the times it a no go
Mike in Mass is offline   Reply With Quote
Old 05-15-2018, 04:03 PM   #10
tubman
tubman's Avatar
That's probably one of the reasons the H.A.M.B. went through the painful process of changing their "Bulletin Board" software a couple of years ago.
Old 05-15-2018, 07:41 PM   #11
edhd58
edhd58's Avatar
I found using a lower resolution on my camera makes the pics upload no problem.
edhd58 is offline   Reply With Quote
Old 05-15-2018, 11:21 PM   #12
johnnyford
Thanks Ralph!
Old 05-15-2018, 11:23 PM   #13
johnnyford
Yes Sir went to a thursday night gathering then a Saturday morning.
Here is one pic of the cars & coffee and one from this afternoon.
I also put the inner wheel well in on the driver side and also the lower fender braces.
and hooked up the led fan switch for the AC.
got two estimates on the Exhaust too, right now i have flex pipe with mufflers alot of fumes.
Mart.
Old 05-15-2018, 11:34 PM   #14
johnnyford
So my issue was not the res size there was just no options for pics but as told by one of the members go advanced has the ticket!
here ya go!
Old 05-16-2018, 02:49 AM   #15
alandomer
Nice pics. That's a sweet looking ride you got there.
alandomer is offline   Reply With Quote
Old 05-16-2018, 03:35 AM   #16
mercman from oz
mercman from oz's Avatar
Now I can see your 36 Ford Five window Coupe better. Nice.
Old 05-16-2018, 05:27 AM   #17
dwick01
dwick01's Avatar
Nice!!
dwick01 is offline   Reply With Quote
Old 05-16-2018, 08:16 AM   #18
johnnyford
I was trying to do that but couldn't figure that out!
new to forum thanks
Old 05-16-2018, 08:22 AM   #19
V8COOPMAN
V8COOPMAN's Avatar
new to forum thanks
That's easy! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-16-2018, 08:26 AM   #20
johnnyford
thanks for sharing
