Old 05-01-2016, 05:39 PM   #1
Pilotdave
Pilotdave's Avatar
Default #51 6 bulb source? UPDATE
I need a 6 volt miniature bayonet #51 bulb for my Signal Stat 900 directional light system. Does anyone know a bricks and mortar store that sells these bulbs?
Thanks!
Dave
See #13 for update.
Pilotdave is offline   Reply With Quote
Old 05-01-2016, 06:07 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: #51 6 bulb source?
I think maybe Snyder's??
Paul
Old 05-01-2016, 06:13 PM   #3
SeaSlugs
SeaSlugs's Avatar
try napa? they have alot of oddball parts, maybe an electrical supply store? a real one not menards or lamp depo or something i mean an industrial place like fastenal, or grainger.
sometimes old old hardware stores still have a variety of bulbs around.
i know you said physical store but amazon has a 10 pack for $8...
http://www.amazon.com/10-PACK-Eiko-M.../dp/B003JW0F2E
macs for buck a piece
http://www.macsautoparts.com/ford_tr...t-bulb-51.html
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-01-2016, 06:18 PM   #4
Mitch//pa
Do a google search lots show up "#51 bulb 6volt"
http://www.cmwauto.com/MainMenu/Lamp...lamp_bulbs.htm
Old 05-01-2016, 06:23 PM   #5
JOHN CT
JOHN CT's Avatar
Around my area we have a store called Battery Plus. They're a chain store. They carry a larg assortment of light bulbs. Check to see if you have one in your area. And give them a try.
JOHN CT is offline   Reply With Quote
Old 05-01-2016, 06:27 PM   #6
jrelliott
jrelliott's Avatar
You should be able to find one in your area also called BA9S. Since Radio Shack no longer supplies parts. I did a search on the internet for #51 bulb and there are a lot of LED bulbs that will replace that bulb and should last you a lifetime. Bulb Town has the for less that $.75.
Old 05-01-2016, 07:32 PM   #7
Bob C
The NAPA part number is LMP51
Old 05-01-2016, 07:37 PM   #8
Pilotdave
Pilotdave's Avatar
Thanks for all the replies! I'll start with NAPA in the morning.
The back story: after trying a variety of things to get the indicator lights in the Signal Stat to light up, I finally took it apart and found........no bulb!
Dave
Old 05-01-2016, 07:48 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
The trouble is all the LED bulbs I've seen are only for negative ground systems, even if they claim they work on my positive ground car. I had to leave the business a negative on ebay because he lied about the application and wouldn't refund my money.
Old 05-01-2016, 08:03 PM   #10
Bruce Adams
Bruce Adams's Avatar
Hi Tom,
How/why does a bulb know which side is ground?
I have never tried to put hot to ground and vice versa but I would THINK a simple bulb should work.
No?
Bruce Adams is offline   Reply With Quote
Old 05-01-2016, 08:09 PM   #11
Tom Wesenberg
Regular bulbs don't care about polarity, but LED needs the current to flow the correct direction.
Old 05-01-2016, 08:10 PM   #12
Bruce Adams
Thanks. I was trying to delete it after seeing LED Best-Bruce
Old 05-03-2016, 04:10 PM   #13
Pilotdave
Pilotdave's Avatar
Default Re: #51 6 bulb source? UPDATE
Order the bulb through my local NAPA shop. Installed and working! Thanks for the assist.
Dave
Old 05-03-2016, 04:57 PM   #14
SeaSlugs
SeaSlugs's Avatar
what did they take outa your pocketbook for the bulb? curious...
Old 05-03-2016, 09:44 PM   #15
Pilotdave
Pilotdave's Avatar
I had to buy a box of ten...about $8.50 for the box, so $0.85 for one bulb.
Old 05-03-2016, 09:56 PM   #16
C26Pinelake
It could have been worse! Wayne
C26Pinelake is offline   Reply With Quote
Old 05-04-2016, 08:54 AM   #17
Bruce of MN
Bruce of MN's Avatar
In the UK, try http://www.norbsa02.freeuk.com/goffystandardbulbs.htm
