02-18-2015, 07:55 PM | #1 |
A little knowledge goes a long way
I thought some of you might like this:
http://www.goldengatev8.org/tips/Evo...heFlathead.pdf |
02-18-2015, 08:04 PM | #2 |
Re: A little knowledge goes a long way
Wow! Now that's a really good article. That should be put out in paper form and sold. (I can't keep track of stuff on the internet at all).
Thanks! |
02-18-2015, 08:38 PM | #3 |
Always good to unforget some stuff... Thanks!
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
02-18-2015, 10:35 PM | #4 |
An excellent read! Did the 1946-1948 Merc engines hsve 59 stamped on the bell housing sometimes? I read where they sometimes had 99 stamped on them.
Great reference! Thanks Ron!
Son, you will never blow an engine up in high gear. |
02-18-2015, 11:23 PM | #5 |
The 99 series blocks were 39-41 with a 3 3/16 bore, and a 2.138 crank. This is where the 29A floating rod came from. And yes All blocks made from 46-48 Ford or Merc had the 59 on the bell housing. This also made the 3 7/8 stroker crank.
02-18-2015, 11:25 PM | #6 |
02-19-2015, 01:13 AM | #7 |
So the Canadian 8AB blocks were all unmodified '49 blocks?
02-19-2015, 03:44 AM | #8 |
Fred Mills, the author of the piece, is our own 38 coupe here on the Ford Barn. While I am embarrassed to not remember him, Fred tells me that we met at the 2003 Grand National in Dearborn. The link below is his 4 year old thread developing the piece. Fred kindly sent multiple emails to enable the compilation of his valuable work into the link that Ol' Ron posted. Thanks again, Fred! And thanks to Ol' Ron for bringing it back to the Barn where it began!
If I failed to provide a link for the Barn previously, I do apologize, but I do know I sent the link back to fred with my gratitude when it was published almost exactly two years ago. http://www.fordbarn.com/forum/showthread.php?t=25301 Alan Simpson, http://www.goldengatev8.org/
Alan |
02-19-2015, 11:02 AM | #9 | |
Thanks Ron, this means I could have a Merc engine sitting in my garage. Too dang cold today to find out! It was zero the last time I looked!
02-19-2015, 11:17 AM | #10 |
A great article on the Flathead!! In 1938 or 1939 to 1942 Ford used sleeves in the bores. Did they use them in the Mercury engine also? What was the purpose of using sleeves, was it for better wear of the steel sleeve over the cast iron block?
02-19-2015, 11:58 AM | #11 |
Thanks Ron, great info
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. |
02-19-2015, 01:40 PM | #12 |
Too many questions to answer right now. I was looking through my computer deleting all the junk I save and ran across this article I saved when first posted. I thought it contained so much information in it, it should be re posted.
But the big thanks belongs to Fred Mills for spending the time and effort to make it in the first place |
02-20-2015, 09:04 AM | #13 |
Great read! I have to print this out and save it.
