11-22-2018, 08:21 PM | #1 |
Armored Cable Question
Happy Thanksgiving!
There are many references to shorting issues if the armored cable is screwed into the distributor housing too far. This is one of the bits of wisdom that begs further explanation! What specifically is grounding against what? Thanks much! Dave |
11-22-2018, 08:40 PM | #2 |
Re: Armored Cable Question
The bus bar on the lower plate in the distributor can be pushed into the side of the casting. Repro bus bars are thinner than originals on the ones I've seen. 2 or 3 turns in is enough for the popout end.
11-22-2018, 09:09 PM | #3 |
What Tom says about lower plates being very flimsily is very true, however a few years ago Bratton's started making a very high quality lower plate with the correct thickness metal that fits properly, and if installed properly with the fiber washer on the condenser, will not short out. You can put a screwdriver in the hole where the cable goes and push very hard and nothing moves or shorts out. Got to give Bratton's a attaboy for making a quality part.
11-23-2018, 07:47 AM | #4 |
Thread Tools | |
Display Modes | |
