09-02-2014, 07:34 PM | #1 |
Installing early V8 hydraulics on an A
I did a search to see if someone had mapped out the steps needed to convert the A to early V8 hydraulics, no luck. A friend asked me to see what I could find. He is a master machinist and fabricator, so trimming drums and backing plates etc is nothing for him. The hydraulics are going in an sprint car with an A rear end and front end he is building from scratch, not a real A. No need for comments about mechanical vs hydraulics, as my A has mechanicals and they work fine. This is for re-created race car. Thank you.
09-02-2014, 09:27 PM | #2 |
Re: Installing early V8 hydraulics on an A
Contact:
Cling's Aftermarket Products Inc. 12452 S. 71st St. Tempe, AZ 85284 Phone: 480-777-1201 Owner: Dennis Cling Dennis specializes in hydraulic brake conversions for Model A's. He has a booklet he sells that tells you everything you need to know about the conversion. He also sells all of the conversion parts needed in kit form. He also provides services such as rotating the rear V8 backing plates so that the bleed valves clear the Model A shackle mounts. Dennis is also a nice fellow to do business with. If you are going to run Model A wheels you will also need adapter plates. For these contact: MT Car Products Phone: 530-872-0122 Tom Endy |
09-02-2014, 11:47 PM | #3 |
Why would you bother, Im just taking a set off plus converting to RHD for custmer , Really with proper set up rod brakes & Flathead reds floaters installed they are as good if not better & no maintance needed, just my view having both , Spring has arrived in NZ
09-03-2014, 11:51 AM | #4 |
If you go over to the HAMB, if I remember right, do a search, and I think detailed instructions WITH pictures can be found.
Paul in CT |
09-03-2014, 12:15 PM | #5 |
Yeah, this is the wrong forum. It's like going into McDonald's and asking for a pizza. HAMB is a better bet.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. Last edited by 700rpm; 09-03-2014 at 03:55 PM. |
09-03-2014, 04:28 PM | #6 |
You might even create a car which will do a 180 on a skidding stop... Well, it never happened to me... Joe K
Shudda kept the horse. |
09-03-2014, 05:25 PM | #7 |
Did anyone read the first post in this string?
09-03-2014, 07:07 PM | #8 |
Joe K: No offense but a plain (39-48) conversion doesn't need "proportioning", and if adj correctly "balance" won't be a problem. JMO
Paul in CT |
09-04-2014, 01:35 AM | #9 |
09-04-2014, 02:08 AM | #10 |
Russ,
Check this link out then talk to Dennis Cling. He just helped me with my conversion. http://www.lainefamily.com/ModelAFil...akeUpgrade.htm Andy |
09-04-2014, 10:22 AM | #11 |
russ, hydraulics are ideal for your sprinter for several reasons. they have more brake area and the drums are cast iron being a couple of those. they were designed for cars heavier than the A. i recommend machining .100" off the ends of the A axle housings to allow the backing plates to sit further inboard, otherwise you will likely have interference between the backers and the drums.
Thread Tools | |
Display Modes | |
