03-28-2024, 05:44 PM | #1 |
54 mercury electric fuel pump question
What gauge stranded wire should be used to wire a 6 volt electric pump on the vehicle???
Bob from Northport Northport, Michigan |
03-28-2024, 05:52 PM | #2 |
Re: 54 mercury electric fuel pump question
Where are you placing the pump? AMP of the pump?
See if this helps - https://www.wirebarn.com/Wire-Calculator-_ep_41.html Did you get my last PM? Last edited by KULTULZ; 03-28-2024 at 06:35 PM. Reason: CRS |
03-28-2024, 08:55 PM | #3 |
Yes. I got your last PM. I read everything.
I can NOT find any amp rating on the pump. Its the one you recommended-an AUTOKAY 6 volt pump. It is being mounted on the frame just in front of the left rear wheel, as far back as I can get. I have a bypass built around it just in case. I was an electrician most of my life. I understand voltage drop and amperage. I was just asking what you or anyone used to wire a pump up. 16 or 14 gauge stranded??
03-28-2024, 10:52 PM | #4 |
Ha, another retired electrical guy. Like me. You’ll probably be good with 16, but I’d use 14 just to be safe. I had an electric pump (in a very off topic installation) that was a Bosch. Said it would support up to 930hp in a turbo 911. I used #10 for that one.
I’ve got in tank GM pumps on 2 yblocks. One supercharged, one a throttle body EFI. 40# or so. They’re both on #12. So 14 should be safe. |
03-29-2024, 02:31 AM | #5 |
Do you have the thread where I let my mouth overload my a$$?
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
03-29-2024, 08:16 AM | #6 |
03-29-2024, 10:41 AM | #7 |
Can you post it so I can see what I posted?
03-29-2024, 11:17 AM | #8 |
I don't know how to do that.
03-29-2024, 12:44 PM | #9 |
That name comes up in this thread, and a link to Amazon. Based on the picture that looks like pretty light gauge wire. I’d go up 1 size for the feed and fuse accordingly. But it’s not one of Kultulz’s post.
https://www.fordbarn.com/forum/showt...hlight=AUTOKAY |
03-29-2024, 01:18 PM | #10 | |
I didn't remember suggesting a pump by name. Just trying to CYA here ... Too damn poor to cover a bond ... BTW - AIRTEX was bought/absorbed by CARTER.
03-29-2024, 05:41 PM | #11 |
My mistake. Sorry for the confusion. I found the thread. Go to search and type in adding a electric fuel pump . Merc Cruiser made the recommendation..
03-30-2024, 08:57 AM | #12 |
No big deal. I try and not recommend brands as if it comes back on me, I will be a bigger SOB than I am now ...
03-30-2024, 10:53 AM | #13 |
still lots to learn
