12-09-2015, 03:03 PM | #101 |
Re: 5 main, chev, crankModel A engine
Here you go. the two main webs that were added, the lines hook to the bottom. I put fittings in there before they were installed. The other three go through a hole in the web, the inserts will go over top of them.
12-09-2015, 06:21 PM | #102 | |
What type distributor will you run/use ? |
12-09-2015, 06:30 PM | #103 |
12-13-2015, 01:24 AM | #104 |
12-13-2015, 09:07 AM | #105 | |
I will post a picture when it is installed. |
01-02-2016, 03:45 PM | #106 |
01-03-2016, 01:43 AM | #107 |
Wow. Please post a video when it runs. I would really like to hear it. Any more thoughts
on the balancing? |
01-03-2016, 09:18 AM | #108 | |
My plan is to take it to the hill climb in May. But I have a good hot engine waiting just in case this one does not do well. |
01-03-2016, 10:28 AM | #109 |
George, is this going in the red one or the blue roadster? Been following this and would sure like to see a video also when completed. Amazing work and detail. Good luck with it and Happy New Year.
01-03-2016, 11:13 AM | #110 |
Maybe I'm jus a goober,..but this is just amazing to me!! The ingenuity, machining, and overall imagination,....just amazing!! Fantastic Mr Miller, you have my utmost respect!! I too can't wait to see/hear it run!!
Rowen
Alive n kickin n mostly kickin! |
01-03-2016, 12:43 PM | #111 | |
So making a new one out of parts that are laying around. Here is a picture of the new one and a picture of the red one with the 4 port engine. Last edited by George Miller; 01-04-2016 at 09:34 PM. |
01-03-2016, 12:45 PM | #112 |
Thanks for the kind words. Just had the right Dad and jobs in my life that pointed me in this direction.
01-03-2016, 06:56 PM | #113 | |
01-13-2016, 08:29 AM | #114 |
Up date.
Back working on my engine. pistons are in, oil pump ready to go, cam timing done, dist just about ready, working on front damper for crankshaft. The little things take a long time to do on some thing like this. No pictures because you can not see what was done. The oil pan and head will be soon. |
01-15-2016, 01:40 PM | #115 | |
Since your crank is sbc (?) , would not a balancer common to that crank/engine work ? If not, could you explain details of why and what has to be changed/why ? |
01-15-2016, 02:24 PM | #116 |
Should be more pictures today. Hard times I end up using a balancer from a 4 cylinder 151 chev. Mostly because I had one.
01-15-2016, 02:27 PM | #117 |
All this makes the phrase that comes to mind: "Ford Tough - with Chevy Stuff"
01-15-2016, 04:10 PM | #118 |
Here are some pictures of trial fit of head. Every thing looks ok except will need a little longer push rods. Lets paint it.
01-16-2016, 11:52 AM | #119 | |
Regarding making new pushrods, what materials....and HOW do you get proper LENGTH .... And, how critical and close is proper length...for mechanical and hydraulic lifters..is thinking different on each kind ? |
01-16-2016, 01:19 PM | #120 | |
42 High Tech Boulevard Thomasville NC 27360 PH 800-448-1223 If you get them from them they will tell you how to measure. It was something like 140 from the end of the push rod. |
