07-05-2023, 11:45 AM | #1 |
direction oil pump turns
I have a new oil pump for my 29 and need to prime the pump. Which direction does the pump turn, clockwise or counter clockwise? I will immerse it in a can of oil and turn it with my drill to prime it enough to lube the gears. It might not be necessary but I will be more confident there will be oil on startup.
07-05-2023, 11:57 AM | #2 |
Re: direction oil pump turns
Counterclockwise looking from the shaft end- just like the distributor looking from the top.
07-05-2023, 12:03 PM | #3 |
Thanks, I will install my oil pan now.
07-05-2023, 12:08 PM | #4 |
Be sure to place a small bucket or cup next to the hole where the oil squirts out so that you can catch the exiting oil. Otherwise, the pump will send a stream of oil halfway across the garage! MESSY!
Marshall |
07-05-2023, 01:43 PM | #5 |
To prime the engine you can pour the last quart down the hole that the distributor goes in.
07-05-2023, 03:43 PM | #6 |
07-05-2023, 03:47 PM | #7 | |
07-05-2023, 03:56 PM | #8 |
oldspert,
As nkaminar says, I highly recommend pulling the distributor and pouring at least 2 quarts of oil down the hole to help prime the pump and flood the lifter gallery and upper main bearing oil supply. Everything gets a good baptism in fresh oil. Nothing is disturbed by pulling the distributor and it is easy to slip back in place - your timing and point gap are not affected in any way. (Let me know if you need help. Your friend down the road in Waxahachie! ) |
