09-30-2013, 09:56 AM | #1 |
Super Winfield head info needed
Last weekend I bought what i assume to be an original super Winfield aluminum high compression head. I've tried doing some research to find out what compression it is. I've read 7:1 and 8:1. My head is casting #104 and there is another number next to the casting # that reads 8.25. I'm not sure if that is the compression or not. If some can confirm the compression ratio i would appreciate it. I bought this head for when I build a hot motor for my speedster once I get caught up from building the speedster in the first place.
Cowtown A's |
09-30-2013, 10:39 AM | #2 |
Re: Super Winfield head info needed
The only way to know for sure is to CC it, and calculate the CR with your cylinder volume. Good Luck.
09-30-2013, 10:52 AM | #3 |
