10-24-2015, 06:05 PM | #1 |
Starter bushing, brush end
Where do you fellows buy your bushings for the end plate with the brushes for a model A ford. I've had no luck with the ones from a vender. Thanks, charles
10-24-2015, 10:16 PM | #2 |
Re: Starter bushing, brush end
Mikes a fordable, http://www.mikes-afordable.com/product/A11052.html
10-25-2015, 01:18 AM | #3 |
Unless it's actually worn out there is no need to replace it. Total time on a starter is very little and the rear bushing has very little load on it. That said, if I had to replace the bushing (I've only had to do a couple) I either bought it from Bert's, Bratton's, or Snyder's, and it fit fine.
I also have a very good seal and bearing store about 5 miles away where I can buy parts if I need to. |
10-25-2015, 12:09 PM | #4 |
Tom and others, I bought 3 from one of the venders mentioned above and had no luck with them. Maybe need to try a different one. Thanks for the help guys.
10-25-2015, 10:01 PM | #5 |
10-26-2015, 11:42 PM | #6 |
10-27-2015, 10:03 AM | #7 |
So that's where the problem lies, Tom.
Charles |
