05-16-2011, 07:35 PM | #1 |
drilling holes in the flywheel
i might have to drill some new mounting holes in my flywheel to except a new bolt hole pattern for a 10" long pressure plate. i have heard of guys doing this, wount this throw off the balance on the flywheel?....
kendall |
05-16-2011, 07:53 PM | #2 |
Re: drilling holes in the flywheel
If you get it centered exactly and drill and tap all the holes exactly the same you shouldn't mess up the balance . A drill press with a stop would be a good idea for getting the holes all the same . David J
05-16-2011, 07:58 PM | #3 |
Maybe drill out a few extra to lighten it up. Old skool...slim
05-16-2011, 08:01 PM | #4 |
when you drill & tap it you have to have a counter sink for the special shoulder bolts get the proper bolts & mike & measure them so you do the job right
05-16-2011, 08:07 PM | #5 |
this is how I did it, jig drilled a transfer drill fixture. I don't see how balance can be effected when the new pattern is equally spaced from the old one.
05-16-2011, 08:20 PM | #6 |
05-16-2011, 08:44 PM | #7 |
thats clever wouldnt have thought of doing it that way simple
05-16-2011, 08:47 PM | #8 |
Kendall,
Gotta be CONCENTRIC. My comfort level is using a milling machine and a center spindle. If you are located near western New York I'll do it for free. Charlie ny |
