Old 06-20-2015, 08:32 PM   #1
Mitch//pa
Default bug etching
any installation tips other than the insructions that come with the kit? i am doing this with the w/shield installed.
this is my first bug install
Old 06-20-2015, 10:00 PM   #2
bunnyc
bunnyc's Avatar
Default Re: bug etching
found this post. it may be helpful. http://www.fordbarn.com/forum/showth...ht=bug+etching
bunnyc is offline   Reply With Quote
Old 06-21-2015, 12:25 AM   #3
Mitch//pa
thanks bunny i read that one and a few others
Old 06-21-2015, 02:05 AM   #4
Floats
Floats's Avatar
Hi Gents,
Please excuse my ignorance, what is bug etching?
Floats is offline   Reply With Quote
Old 06-21-2015, 02:21 AM   #5
Mitch//pa
Originally Posted by Floats View Post
Hi Gents,
hi float
bug etching is engraving the appropriate trademark into the glass using a chemical and stencil. here are some examples of available bugs. the JS book goes over whats proper and where for a particular car// year.
the kits are available through eBay, Michael is the main supplier of these and is on the ford barn also.
http://www.ebay.com/itm/351273393165
thanks for asking
Old 06-21-2015, 02:54 AM   #6
Floats
Floats's Avatar
TKS Mitch,
Have a great Fathers day.
Regards
Chris
Cape Town
Old 06-21-2015, 04:40 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Mike Driskell is a close friend of Roy Nacewicz, -which is probably where the logo-ing kit came from.
As far as the actual process, we have likely done it several hundred times over the years. Here is my way. I think this is a product of practice makes perfect, so use some scrap glass to practice on. The glass must be extremely clean. Soak the template thoroughly in water and apply to the glass and let it almost completely dry. As long as it is a little damp, it stays adhered to the glass. Apply the acid and count to 10 before flooding the glass to dilute the acid. Wipe clean. If the glass is a tad fuzzy in that area, use some fine rubbing compound to polish the area.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-21-2015, 05:54 AM   #8
Mitch//pa
thanks Brent i will practice on some old glass pieces. is there any difference when doing this with the w/shield installed? what about keeping the chemicals off the paint?
Old 06-21-2015, 06:17 AM   #9
Pete / MA
Pete / MA's Avatar
Etching info.
http://www.glassetchingsecrets.com/
Pete / MA is offline   Reply With Quote
Old 06-21-2015, 09:36 AM   #10
mshmodela
mshmodela's Avatar
Float thanks for asking, Mitch thanks for answering...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 06-21-2015, 01:29 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Vermins' "BUGS" are in ALL kinds of GOOFY locations, even the 1/4 window locations DON'T match up. Somewhere, 1 is UPSIDE DOWN. "THEY" shouldn't sell the stencil kits, WITHOUT a BREATHALIZER TEST!
"Maybe" the UNIQUENESS makes Vermin worth MORE??
Whoever painted him, must have NOT made himself bolt the spare tire holder to the new body paint. He carefully crafted a 1/8" thick, RED RUBBER gasket, to go behind the rack! I LIKE IT!! The cowl is also shimmed with the same RED RUBBER. The body has been sectioned, right across the sill plate, I DON'T know if Vermin got a NEW ass end or a NEW front end??
Chop Shop Bill W.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-21-2015, 07:28 PM   #12
C26Pinelake
When purchasing replacement glass from some of the Model A vendors ( Macs ) you can pay an extra fee and have the glass etched when it is sent to you. Usually local glass companies don't offer this luxury! Wayne
C26Pinelake is offline   Reply With Quote
Old 06-27-2015, 11:30 AM   #13
Mitch//pa
i am going to be installing my w/shield bug on my 30 tudor soon. who knows the w/shield frame to bug dimensions for proper placement on the glass...
i checked the JS and Vinces web site but didnt see it
thanks
Old 06-28-2015, 10:53 AM   #14
Mitch//pa
does anyone know this?
Old 06-28-2015, 12:52 PM   #15
BILL WILLIAMSON
I'll ask Buster T.
Dad & Dog
(He sed it's 3 claws frum the side & 3 claws frum the bottom, sittin' in Mommas' seat & lookin' out thru the windscreen.)
Old 06-28-2015, 04:35 PM   #16
Jeff in BC
Jeff in BC's Avatar
Hi Mitch:
Libby says it's too hard to measure while were driving and that I should measure it When we get home.
This is the position of a July 1936 Ford replacement window installed in a 1928 Tudor.
I'm not sure if this will help you but it might help someone else in the future.
Jeff
Jeff in BC is offline   Reply With Quote
Old 06-28-2015, 05:12 PM   #17
BRENT in 10-uh-C
Mitch, you do realize that originally the "bug" was in the plastic that was laminated --and not etched into the glass itself. From originals I have seen, they were very near the edge but we're not exact in location.
BRENT in 10-uh-C
Old 06-28-2015, 05:46 PM   #18
Mitch//pa
no i did not know that interesting and as far as location i'll just put it where it looks good on the lower r/s corner.. i thought for sure someone would have an exact location, but maybe it was like engine stamps a little this way or that way.
thanks Brent
Old 06-28-2015, 05:49 PM   #19
Mitch//pa
Hi Jeff & Libby
thanks for your response and offer of help. Libby looks like she had a tough day lol
Old 06-29-2015, 12:21 AM   #20
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Now you see I would have thought that they would have made large sheets and "cut out" the windows from that. I never would have guessed they started with glass and plastic cut to size then assembled and then heat sealed.
