Old 08-18-2012, 11:50 AM   #1
Kevin in NJ
Default Drive Shaft Sleeve Install and Remove Video
My brother (Kurt in NJ) has some simple ways to install and remove a drive shaft bearing sleeve. We put together a video of the process and put it up on YouTube.
This is our first attempt so hopefully what is done in the video is understandable.
Driveshaft bearing sleeve video
I have attached 2 pictures of tools that are used.
On the left is the KRW tool.
The middle tool is something I made based on what was posted in the past. It will work, but is not as simple to use.
The tool on the right is what my brother threw together on a whim in years past. It is a piece of 1" galvanized pipe with a 1/4"-20 screw put in offset. The handle is just a 1/2" drive socket that happened to fit in the pipe and was beat in some to hold and a sliding T handle.
The socket being used to install the bearing sleeve was just one that fit. Small enough to well clear opening and large enough to support the sleeve. This socket happened to be 1 5/16", but again this will vary on socket construction. This was the first one out of the tool chest that looked like it would do the job.
Hope this helps some.
Kevin in NJ is offline   Reply With Quote
Old 08-18-2012, 01:31 PM   #2
Rusty Homestead Fl
Rusty Homestead Fl's Avatar
Default Re: Drive Shaft Sleeve Install and Remove Video
A picture (video) is worth a thousand words. Well done and thanks.
Rusty Homestead Fl is offline   Reply With Quote
Old 08-18-2012, 02:21 PM   #3
redmodelt
redmodelt's Avatar
Great, thank you for taking the time. Great idea to take the edge off. Part of my not understanding was the taper in the drive shaft tube. Now that I know that all this pieces come together. I bet even in the Model A days the Wilson rep. came by the shop to show how the latest tool were to be used, your video does just that.
Old 08-18-2012, 05:20 PM   #4
d.j. moordigian
d.j. moordigian's Avatar
Kurt & Kevin,
You two guys get an A+ for this video....thank you.
d.j. moordigian is offline   Reply With Quote
Old 12-10-2013, 08:34 PM   #5
Joe K
Joe K's Avatar
Both of these methods are VERY good. I've never seen the KRW tool used before either.
For my rear end rebuild I seem to remember removing this sleeve by a LONG piece of 1" pipe inserted from the flange end of the torque tube. Caught the seal and pushed both out the top spherical end of the torque tube.
Going back together for me was more an alignment thing, and then walking the sleeve back into position using a punch alternately.
Today I would use the lathe to make an insertion tool similar to the KRW tool (shoulder on a cylinder) but without the nib - and just count on alignment for getting the dimple to seat.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 12-10-2013, 09:43 PM   #6
48fordnut
48fordnut's Avatar
Excellent
48fordnut is offline   Reply With Quote
Old 12-11-2013, 08:34 AM   #7
gweilbaker
gweilbaker's Avatar
Thanks Kevin, very informative.
gweilbaker is offline   Reply With Quote
Old 12-11-2013, 12:02 PM   #8
Brentwood Bob
Thanks, Bob
Brentwood Bob is offline   Reply With Quote
Old 12-11-2013, 07:09 PM   #9
Ed Saniewski
Ed Saniewski's Avatar
Thanks Kevin, I just got done installing mine but am having a problem dropping the roller bearing in. I can tap it in but it dose not fall in. I am going to disassemble the torque tube and remove the sleeve and see if I missed some dirt in the dimple. That is the only thing I can think of that could be causing the problem. I was hoping that you and your brother were going to insert the bearing at the end of the video, but alas maybe on the next on. Ed saniewski
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 12-11-2013, 08:27 PM   #10
Tom Endy
Tom Endy's Avatar
Regardless of what method you used to install the sleeve, shine a light on it and look carefully at the circumference and look to see that the sleeve is up tight against the inner wall of the torque tube. If you detect the slightest gap anywhere in the circumference it means that the dimple in the sleeve is not properly seated in the dimple in the torque tube.
Unless you have the KRW tool or something similar you are not going to be able to rotate the sleeve. You will have to drive it out with a socket along with the seal and start over.
When you go to install the roller bearing it usually does not drop or slip in as some have mentioned. You have to consider that there is some "droop" in the unsupported end of the drive shaft that will bind on the bearing as you start it in. You may have to lift the end of the drive shaft up slightly to get it to go in. Once it starts in I use a 1&1\16" half inch drive, six point deep socket to tap it the rest of the way in. This particular socket easily slides over the splined end of a Model A drive shaft. If the sleeve is not seated properly the roller bearing won't go in over the drive shaft.
A word of caution, there are some really poor quality bearing sleeves in the market place. Some don't even have the dimple. I much prefer to use an original, but I have used ones from Bratton's and they work fine and are made the same as the original, however, I am not sure they are made out of the exact same material as an original.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 12-29-2013, 12:25 PM   #11
Steve Plucker
This is excelent...Just what I was looking for.
Wish I would of known about this a few days ago...would of saved me a PM!
Thanks Kevin and Kurt...
Pluck
Old 12-29-2013, 12:54 PM   #12
1930artdeco
1930artdeco's Avatar
How does the 1/4 bolt go into the dimple without scoring the sleeve above it?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 12-29-2013, 01:04 PM   #13
Steve Plucker
Mike
Great question Mike...I was thinking the same thing.
Pluck
Old 12-29-2013, 01:38 PM   #14
Kurt in NJ
Kurt in NJ's Avatar
The KRW tool has a spring loaded plunger, My quick made from scrap tool the bolt is short enough that it can be fitted into the hole without touching the bearing surface, it doesn't fit into the dimple, it fits into a hole ---there is no scratching or dragging across the bearing surface, the piece of pipe is smaller than the diameter of the inside ,the bolt is set to one side so it grabs the hole 90 degrees to the hole, the end of the "bolt" is rounded just enough that there are no sharp edges to dig into the torque tube, but not so much that it can't grab the hole in the sleeve ---
Old 12-29-2013, 01:52 PM   #15
Steve Plucker
Thanks Kurt for the information!
Pluck
