Old 05-25-2013, 08:03 PM   #1
Mitch//pa
Default transmission
on my current lucy restoration i am now going thru the trans, basically just opening it up looking for cancer, upgrading / freshening the bearings and shafts with orings etc . the trans worked fine and was quiet no whines. the only main thing i came across was the input shaft pilot was welded and ground, also loose on the pilot bearing. i heard of buying a different pilot bearing with a smaller input hole and turning down the nose to fit. anyone do this ? i am thinking of buying new input shaft usa made and hoping it does not create a whine. you can see more pics of this project in my lucy restoration album..
Old 05-25-2013, 09:08 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: transfusion
Yes my car has the turned down shaft. The bearing, and I don't know the size off hand comes in two different inside bores( the same OD).works just as well as the normal one.
Old 05-25-2013, 09:14 PM   #3
Pete
While that looks like a very poor welding job, it should work if it is the right size.
Old 05-25-2013, 09:32 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
My choice would be to weld it up and turn it back to stock size, but either way should work fine.
Old 05-25-2013, 10:03 PM   #5
Drive Shaft Dave
What I did on a couple of input gears is, turned the worn part down true, the made press fit sleeves for them, then you can stay with the standard bearing.
Drive Shaft Dave is offline   Reply With Quote
Old 05-25-2013, 11:04 PM   #6
columbiA
You could turn the nose of shaft down to accept a#203 Special brg which has a smaller ID.It would be wise to leave a note to the next owner of the car of the change ,otherwise he wouldnt be able to fit another trans into the pilot brg!
columbiA is offline   Reply With Quote
Old 05-26-2013, 12:28 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
When securing some bearings for Sear's lawn equipment, I found that some of their bearings are the same O.D. as some standard bearings, but the I.D.s are smaller! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-26-2013, 07:55 AM   #8
Mitch//pa
Thanks all for the replies,
Dave where would one get the press fit sleeves?
Columbia thanks for the # 203 thats what i needed and will cross reference it and see what comes up
And yea where would you stick the note telling the next guy that goes to put a trans in? Maybe inside the housing
Old 05-26-2013, 11:36 PM   #9
BILL WILLIAMSON
Your "note" reminded me, I have always put a folded $5.00 bill under the L/F scuff plate on every Model A I've owned. (Emergency gas money) I'm sure that I have forgotten to retrieve some when I sold the cars. NOBODY ever looked me up to return it!
Chief always carried a $50.00 bill, folded lengthwise in the sweatband of his hat. Bill W.
Old 05-27-2013, 01:42 AM   #10
Mitch//pa
haha bill
nowadays that might need to be a 20.00
Old 05-27-2013, 09:55 PM   #11
Drive Shaft Dave
The sleeves I made myself , turned them out on a lathe.
Old 05-27-2013, 10:11 PM   #12
Rich in Tucson
Rich in Tucson's Avatar
Bill, a friend who recently passed away hid emergency cash everywhere, and a car sold after his death turned up $150 in 50 cent pieces (he got rolls from banks, removed the silver ones, and sold them for ~$3.00 apiece or so). The car was sold to some youths who turned up several days after the car sale to return the cash to his grateful widow; maybe there is hope after all. Still looking for a pistol and ammo he hid somewhere....
Rich in Tucson is offline   Reply With Quote
Old 05-28-2013, 12:47 AM   #13
BILL WILLIAMSON
Rich,
After Momma passed away, we found $21,000 above the little square lid in her closet ceiling! The clue was a little step stool she always kept in the closet, with bits of grass & dirt on the steps.
A friend hides stuff in the same kind of closet hole that drops down to the crawl space.
I keep my "GLOCK" in the bottom of my pillow case. (Only the Dog knows!) Bill W.
Old 05-28-2013, 06:54 AM   #14
Mitch//pa
thanks dave
bill keep the safety on
