#1 |
I am getting a new 5.5 high compression head, which head gasket do you prefere ? And why ?
Mike |
#2 |
Copper Felpro 7013 R4 with copper spray. proper torgue technique I do mine always Cold Engine.
www.whidbeymodelaclub.com |
#3 |
Per Snyder's instructions:
You must use the 1932-34 "B" style head gasket with this cylinder head. I use their "Premium Gasket"
#4 |
Ask the vendor for the recommended gasket.
#5 |
Mike I have installed this both ways. I like the Premium gasket that Snyder's sells but have had 3 on different cars blow gaskets in the last year on fresh installs. Don't really know why and they all blew in different areas. Consensus around this neck of the woods is the all copper gasket is more reliable. I still am running the Premium gasket on my coupe without issue.
Oklahoma City Model A Restorers Group. |
#6 |
From Snyder's: 'B' Head Gasket
#7 |
I have the Snyder 5.5 head on my coupe. I installed the recommended felpro gasket twice. It seeped both times around the serial numbers on the block. I talked to an old Model A'er about the problem. He recommended using a quality copper clad Model A head gasket and to coat both sides of the copper head gasket with a thin coat of axel grease. I followed his advice. The head has been on for 6 years and about 14,000 miles with no seepage at all. Further, should you need to remove the head in the future, it will pop right off as there is no sticky sealant involved. JMO
#8 |
re Dick,
axle grease.......... I like that. Makes a heck of a lot of sense. |
#9 |
First time I reinstalled the head on my coupe my father told me same thing. He said it is what they did. I didn't understand the science but I trusted him completely and installed the used copper gasket that way. Never had a problem with it.
#10 |
I use the copper clad head gasket with lots of copper coat spray. I usually retorque hot and then again the next day cold, but I don't think that really matters. Just retorque several times over a couple of days.
#11 | |
![]() Quote:
#12 |
Thank you everyone !!
Mike |
#13 |
I only said that is what Snyder's says. It works for me, but then what do I know, I've only done one engine, not 50. And I was just following the manufacturer's instructions.
#14 |
Has the Snyder head been out long enough to have done 50? (just asking)
#15 |
Where do I purchase a copper felpro 7013 r 4 gasket
#16 |
You only need the stock felpro 7013 the R4 version from my memory is for engines bored to 4 inch
Another good gasket is Best 509 I use this why I have changed Valves |
#17 |
I understand that and didn't mean any insult. I just don't understand why a distributor would suggest something they don't have any reasonable proof of. I guess it sells a more expensive part.
#18 |
Any good auto parts should be able to order one for you.
