Old 07-23-2014, 12:47 AM   #1
Rowdy
Default Horn Hardware Change?
I was disassembling the 5 horns that have been taking up shelf space waiting to be rebuilt. On the two Spartons and two of the SW's the flange nuts took a 7/16" wrench. But on the other SW the nuts took a 3/8" wrench. Was there a hardware change somewhere along the way or did someone in the distant past make a substitute? I read the JS and seen no mention of any change. Alittle input is apriciated. Thanks Rod
Rowdy is offline   Reply With Quote
Old 07-23-2014, 01:06 AM   #2
Ron in Quincy
Ron in Quincy's Avatar
Default Re: Horn Hardware Change?
Rowdy,
I believe the Standards are correct. Probable someone in the past rebuilt the horn and installed a new set of bolts and nuts ?
Ron
Ron in Quincy is offline   Reply With Quote
Old 07-23-2014, 06:10 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
My October 1, 1929 Parts Price List calls for the 3/8" nuts and they are painted black enamel.
I'd have to look up the other dates for the Parts Price Lists to see if they changed size.
Old 07-23-2014, 06:52 AM   #4
Rowdy
Thanks Tom. This horn is the one that came with the donor fordoor that I am using the chassis for the delivery sedan. The numbers are April 1929 and the car was a one family car with 67,000 miles. The horn did not show any signs of ever being apart. Rod
Old 07-23-2014, 07:21 AM   #5
Tom Wesenberg
This needs more research because I think I've come across both sizes for the nuts also.
Old 07-23-2014, 07:36 AM   #6
Steve Wastler
Steve Wastler's Avatar
According to Brattons catalog, Sparton and stewart warner used 7/16 nuts, Ames and GMI used 3/8
Steve Wastler is offline   Reply With Quote
Old 07-23-2014, 08:34 AM   #7
Rowdy
Speaking of Ames horns, one of the Sparon horns had an Ames mounting bracket. So far Ames is the only brackets I have seen that had their logo on them. Rod
Old 07-23-2014, 09:09 AM   #8
Steve Wastler
I have one bracket with Ames, all others blank as stated above
Old 07-23-2014, 09:32 AM   #9
d.j. moordigian
d.j. moordigian's Avatar
Rod,...it's in the chart, page 19-2, of the 2011...
d.j. moordigian is offline   Reply With Quote
Old 07-23-2014, 09:45 AM   #10
CAPE A
Talking horns, I have a horn the cover says Sparton the flange has sparton stamped into it however the tag is not like a the sparton tags ive seen shorter wider grey with a letter and a # stamped into it. any other writing is gone. Under the back cover looks just like a sparton.I did get this from a old time model A guy that said it is a sparton. Any ideas ?? Thanks CAPE A
CAPE A is offline   Reply With Quote
Old 07-23-2014, 10:18 AM   #11
Rowdy
Thanks DJ. I do not yet have the 2011 version of the JS. Been paying too many med bills to even considering a non-esential item. I bought some hard to find parts for the hotrod, but atleast got back to even with the purchase by selling the things in the pile that I did not need. Maybe next year I can get back to working on the delivery and will buy the newer JS. Rod
Old 07-23-2014, 10:26 AM   #12
d.j. moordigian
Boy, do I understand! Try this, the chart, page 19-2, 1997...
Old 07-23-2014, 09:38 PM   #13
Rowdy
Thanks DJ. I was heavy into reading hard text that I don't even think I seen the chart.
Also when ordering parts today I noticed that Ames horns take different brushes. Not listed in the parts book. Where does one buy brushes for the Ames, a friend of mine needs a set. I have not looked at the A&L parts list yet. Thanks Rod
Old 07-24-2014, 09:35 AM   #14
d.j. moordigian
I have an AMES,...just thought I would modify a set of brushes to fit!?
Old 07-24-2014, 10:06 AM   #15
Rowdy
I hope you are right as I now own the horn. He wanted a working horn for the car show this weekend. He traded it to me this morning for the SW that I had for the delivery and some cash as long as the S W was done by tomorrow evening. I will measure the brush thickness and see if it is slightly smaller than the brushes for the other horns. If it is smaller I will file down a set for it. If they are larger than I will cut some to fit from my stockpile of unidentied brushes. I have a Klaxon I need to make brushes for any way. Also another possible solution is to change the brush holders to the ones currently sold. Rod
