05-30-2024, 05:50 PM | #1 |
Whatisit?
Have a NOS block, dunno what, I am going to get the light rust boiled off, code says 4 bolt main but not seeing that. Know flatheads & learning 289’s but not these things. Ideas?
05-30-2024, 06:37 PM | #2 |
Re: Whatisit?
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
05-30-2024, 06:37 PM | #3 |
Re: Whatisit?
Even blown up I can’t seem to read the numbers on a tablet. But a 4 bolt main is usually pretty obvious looking at the block
05-30-2024, 06:44 PM | #4 |
Re: Whatisit?
'Ya know ... It's posts like this that make me insanely jealous ... ... I just happened to have this laying around NOS... show-off ...
05-31-2024, 08:33 AM | #5 |
Re: Whatisit?
Fresh views, pulled it out of a semi trailer Wednesday, dealership cleaned out in ‘79, suppose I should get it cleaned even though I am not going to use it.
05-31-2024, 08:44 AM | #6 |
Re: Whatisit?
05-31-2024, 05:16 PM | #7 |
Re: Whatisit?
If a person plays around with this stuff long enough, they can looks at those numbers and tell a lot about what it was meant to fit. With Ford's first digit being a decade code and the second being a year of change code then they just have to know what the other numbers mean. The 335 series engines were basically the 351 C and the 400. The 400 changed the family, ie 351M, early on and the oil embargo in the early 70s slowly killed them off.
05-31-2024, 05:22 PM | #8 |
Re: Whatisit?
Numbers on a NOS Block - Rodrelic |
05-31-2024, 05:23 PM | #9 |
Re: Whatisit?
Thank you very much. Would it be good to get it cleaned up or put it out there as is? Don’t believe I will get into this, got too many flatheads
06-01-2024, 01:55 AM | #10 | |
Re: Whatisit?
The BLOCK CASTING ID NO. will be the same for a 2-bolt main or 4-bolt main. The 4-bolt main block was subjected to a different machining protocol. That would give it a different ENGINEERING PN. Find a 351C FORUM and advertise it there. I wish I were still young as these things would run. I had one in a 73 RANCHERO (351CJ) and it would fly and it was a smog motor with a 4300D CARB on it. Perfect swap for a '57.
