Old 03-11-2012, 11:29 PM   #1
Airsho93
Airsho93's Avatar
Talking Battery Cutoff Switch
I am installing a cutoff switch for the battery. I am glad I searched the past forum threads. I was going to install it from the neg to the starter. Wrong...... I found out I should install it from the positive to frame or transmission. That really makes more sense now that I think about it more. My original way could cause some real bad problems if a negative wire came off the switch or some how the switch got loose and rested on the frame. My A coupe be a bit crispy..... Good for the past posts and the guys who write them...
Airsho93 is offline   Reply With Quote
