09-03-2012, 07:00 PM | #1 |
Model A mystery carb...
Carb off the "new" '29 engine... sadly, the throttle-body lost an ear in the same accident that claimed the intake...
I am assuming this is a Tillotson, but the images on Google show die-cast upper body, this one is cast-iron... Plus the idle mixture screw on Tillys seems to point sideways, parallel to the throttle shaft; this one points forward and up at an angle, like a Zenith... More info: went back to garage for another look: round tag on bowl cover reads: 2405N, in an arch. Bowl has "Made in USA" cast into it on engine side, just below parting line. No other indentifying marks. Opened it up, and found something very intriguing: in photo 2, there is a rounded verticl profile on both the carb bowl and the cover; inside is a well with a jet in the bottom and a spring-loaded metering rod(?) & piston in the bowl cover, with a vacuum port in the throttle body, above the butterfly. Choke and throttle butterfly plates are steel, in brass shafts. The throttle butterfly does have some part numbers stamped, and a symbol that is basically the letter " -Z-" inside a split circle... Air horn has an inside diameter of 1-7/8" and an outside diameter of 2-1/16". Last edited by Special Coupe Frank; 09-03-2012 at 08:35 PM. Reason: more info |
09-03-2012, 07:23 PM | #2 |
Re: Carb ID - Tillotson ?
Looks kinda like a Tilly but then it doesn't. It seems to be missing the Tillotson markings. Ive got some Tilly's and Zenith's at the shop that need rebuilt if you need one.
09-03-2012, 07:31 PM | #3 |
The silvery disc rivetted to the top of the cast-iron float-bowl cover has some numbers stamped into it, but I haven't found a name anywhere on the unit....
I have the broken-off piece of the throttle-body; if this carb turns-out to be something decent, I may have a go at brazing the TB back together... |
09-03-2012, 07:33 PM | #4 |
Hey its worth a shot, it looks so familiar but I just cant place it.
09-03-2012, 07:36 PM | #5 |
It could be a tractor from that era. I tried a search of popular cars of that era and didn't match one.
09-03-2012, 07:45 PM | #6 |
I haven't found a match yet... searched on Tillotson, Marvel, Schebler, Holley... |
09-03-2012, 07:52 PM | #7 |
Zenith tractor carbs use the brass tags ... try google with Zenith a space then the number all enclosed in quotes.
09-03-2012, 07:52 PM | #8 |
Could just be a period correct J.C.Whitney kind of carb. I'm kinda hoping someone else chimes in with an actual answer rather than our speculation.
09-03-2012, 08:34 PM | #9 |
Re: Model A mystery carb...
I think I found it!
http://www.ebay.com/itm/Model-B-Ford...-/230686433325 |
09-03-2012, 08:41 PM | #10 | |
By George, you have got it ! I wonder if the performance is any better than with a stock Zenith ? Damn shame about the mounting flange being broken.... SC Frank |
09-03-2012, 08:44 PM | #11 |
yeah, you can try to repair it though and its apparently only worth $50 needing rebuilt. who knows on the performance factor its really hard to beat the old Zenith.
09-04-2012, 12:05 AM | #12 |
Whatever carb you use, performance is limited by the small bore in the manifold just above the carb. Chief described that small bore as "HENRY'S GOVERNOR! "B" manifolds are larger & "A" manifolds can be bored out to use the larger bore "B" carb. But, how fast do we really need to go? Bill W.
09-04-2012, 07:20 AM | #13 |
Good point, Bill...
Not necessarily looking for more speed out of my Flivver; just kind of curious about whether or not the vacuum operated power-valve improves performance / pulling under load.... Would like to know whether this carb is worth trying to revive... Thanks, SC Frank |
