04-22-2017, 12:02 PM | #1 |
Tire wobble
I have NOS Firestone w/w on the 31. The LR has a wobble. I checked and it is not the wheel it is the tire. Eyeball and a stick says about 1/8inch on the sidewall. Is there anyway to correct this?
04-22-2017, 12:32 PM | #2 |
Re: Tire wobble
Mine wobbles as well, I just tightened the drum and will see if that does the trick...
04-22-2017, 12:46 PM | #3 |
Re: Tire wobble
Check the line on the tire just on the edge of the rim, to be sure the tire is fully seated and centered.
I had to spray the tire bead with WD-40 before the tire would correctly slide onto the rim. |
04-22-2017, 01:26 PM | #4 | |
Re: Tire wobble
Bill Quiet
04-22-2017, 03:28 PM | #5 |
Re: Tire wobble
I would let the air out and carefully refill it making sure the tire is centered. Maybe even rotate the tire on the wheel
04-22-2017, 11:14 PM | #6 |
Re: Tire wobble
Me thinks its the WW tires, goodoldfashion BLACK WALLS never wobble😳 Cheers Chris |
04-23-2017, 07:39 AM | #7 |
Re: Tire wobble
BTW it measures 3/8 at the center of the tread. Not good for tire wear.
04-23-2017, 07:47 AM | #8 |
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Re: Tire wobble
It's for sure not his Apple Green wheels!!! Probably just the inside blackwall side that wobbles!!
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
04-24-2017, 06:38 AM | #9 |
Re: Tire wobble
04-24-2017, 08:38 AM | #10 |
Re: Tire wobble
"Maybe" it wobbles from tires that have sat with weight on them, for a LOOONG time & developed a "FLAT" or distorted area????
Bill Questionable
04-24-2017, 09:54 AM | #11 |
Re: Tire wobble
