03-25-2024, 04:28 PM | #1 |
wheel / hub cap fitment issue
Hello guys,
My guess is I have either the wrong wheels or the wrong hub caps... 1931. The ID of the wheel where the cap will be placed is 3 3/4". The OD of the hubcaps I have is 4 1/8". The distance from one bent tab to the one opposite is 3 1/4". Kind of a BB in a boxcar. So, what say you? Thanks.
03-25-2024, 06:08 PM | #2 |
Re: wheel / hub cap fitment issue
I think the larger hub caps fit the early V8
03-25-2024, 06:27 PM | #3 |
Can you post some pictures?
03-26-2024, 05:56 AM | #4 |
Wrong hub caps.
03-26-2024, 08:22 AM | #5 |
So, you believe the hole in the rim is the correct diameter?
03-26-2024, 10:46 AM | #6 |
03-26-2024, 11:06 AM | #7 |
What size are the rims? 21"? 19"? 18"? 17" 16"? Or?
