10-20-2022, 11:30 AM | #1 |
Leakless / Greaseless? Water Pump Cartridge
Quick question: I've got the Leakless Water Pump Cartridge shown in the attached picture and there isn't a hole in the side of the cartridge for grease to reach the unit via the external grease fitting. I'm assuming that I simply grease the roller bearing prior to installing the shaft and that that the only way to add more grease at a later time is to disassemble the pump. Am I correct?
10-20-2022, 11:46 AM | #2 |
Re: Leakless / Greaseless? Water Pump Cartridge
I just installed the same from Snyder's and it comes pre-greased/packed no need to add more. So far my pump is leak free and very quiet. I opted to add the thrust collar to the front to control the end play.
10-20-2022, 11:57 AM | #3 |
I just installed the same from Snyder's and it comes pre-greased/packed no need to add more. So far my pump is leak free and very quiet. I opted to add the thrust collar to the front to control the end play. I bought the rebuild kit.
10-20-2022, 12:01 PM | #4 |
