Old 05-13-2024, 05:25 PM   #1
Fordestes
Default valve parts application
I am trying to use sealed power v1558 valves in my A engine but I only have 5 on hand, I tried to use the sealed power number to buy some more but the warehouses and parts places want an engine vehicle application , they can't or won't cross the numbers over to their brand of parts, The guide application is for a 61-63 olds or pontiac 315 cu. in . engine . I cant find what engine manufacture /application the valves are supposed to fit, luckily I have plenty of valve guides on hand and 5 of the v-1558 valves already or I would just buy the kits available from the model A suppliers. appreciate you help . Fordestes .
Fordestes is offline   Reply With Quote
Old 05-13-2024, 08:58 PM   #2
jetmek
Default Re: valve parts application
I come up with gmc 305 v6 for that valve. Supersedes to s2326. Its not available thru SBI. Maybe try egge or ebay
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 05-13-2024, 09:33 PM   #3
Fordestes
Thanks a lot, I been researching and I was to the point of driving to a vendor and see if they could use the dimensions to identify a crossover application or number , now I can call the parts warehouse and order by application .
Thanks again. Fordestes
Old 05-13-2024, 10:18 PM   #4
PC/SR
Not sure what you are looking for, but call Manley with the dimensions you want, size, length, diameter, etc and they will build it for you and the price is not bad. Google their catalogue and you may find a stock valve that is just right for your application.
PC/SR is offline   Reply With Quote
Old 05-14-2024, 07:03 AM   #5
motordr
I was in the same situation earlier this year, it seems that SP V1558 is no longer made. I found some on eBay under the GM part number.
motordr is offline   Reply With Quote
Old 05-14-2024, 07:18 AM   #6
johnneilson
Try SI valves in So Cal
They make customs or obsolete
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 05-14-2024, 12:52 PM   #7
Fordestes
can you give me the G.M. Part number, mabe I will get lucky, I have 5 on hand and the guides on hand, I am 3 valves short, I I didn't already have the guides ,retainers and keepers I would opt for one of the retro modern valve kits offered, the G.M Valves have an abundance of material on the face and should last for another century.
Old 05-14-2024, 03:26 PM   #8
Dan McEachern
painfull, but.........
https://www.ebay.com/itm/29620413105...Bk9SR7iCvIzvYw
Dan McEachern is offline   Reply With Quote
Old 05-14-2024, 08:36 PM   #9
motordr
The GM part number:2368099.
I was using NOS Model B lifters with my Burtz cam in my Burtz block. The new valves from major model A suppliers were way too short, the V1558 valves where long enough to be shortened to the correct gap.
Old 05-14-2024, 09:31 PM   #10
motordr
Oldsmobile obsolete has one listed.
Old 05-15-2024, 06:44 AM   #11
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by Dan McEachern View Post
Dan, look at the hole in the end. That kinda looks like a Model-T valve.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-15-2024, 11:02 AM   #12
Dan McEachern
Eh- hopefully just a really out of focus picture!!! kinda looks like there might be a keeper groove at the end.
Old 05-15-2024, 04:22 PM   #13
Fordestes
I tried their web site but couldn't find anything , I'll try again ,Thanks.
Old 05-15-2024, 04:25 PM   #14
Fordestes
I think this one may be for sale for a long time at that price.thanks.
Old 05-15-2024, 04:29 PM   #15
Fordestes
that is what I am finding out, I found enough to finish this engine from one of my old sources in Louisiana at $10.00 each , now to find the rest for another engine I have underway , I will need 4 more valves to complete it, thanks for all your help .
Old 05-16-2024, 01:09 AM   #16
Dan McEachern
Just be aware those were never inexpensive valves. I have some and they were about $15.00 each at least 10 years ago.
Old 05-18-2024, 04:39 PM   #17
Fordestes
I want to thank Mr. Bruce for helping me out on my search for the valve train parts, and also I learned a lot of useful information about these cars from him, is .002 interference fit right for the guides press fit in the block, I don't want to trash a good block by forcing the guides into the bores and causing a crack. Thanks Fordbarn !
